586,222 active members*
3,144 visitors online*
Results 1 to 6 of 6
    Feb 2014
    21
    Need Help - Z limit switch problem
    My Z limit switch was having problems so I bought a new one, replaced it and rewired it correctly. Now it still does not work, it does light up but it does not stop, it goes past the limit switch area and hits the top. Again the limit switch lights up, but the machine does not stop, so now I can not Home my machine.
    Also, it had this problem which is why I bought the new limit switch, it is the same switch so that is not the issue.
    Any ideas ?
    15362
    Re: Need Help - Z limit switch problem
    Quote Originally Posted by RMiroC View Post
    Any ideas ?
    What control Software are you using, sounds like a Ports and Pin setting problem or wiring
    Mactec54
    Feb 2014
    21
    I`m using Mach3, any advice appreciated.
    Feb 2014
    21
    Just to add, the machine was working well for a few years, the previous Z limit switch started to be intermittent, so I replaced it and now it is not working correctly, thanks again for any help!
    It has the Leadshine MX3660 too
    May 2014
    21
    I have ran into a similar issue, one of 2 things causeing for me it was heat in the PC (full of Dust) and the second was the begining of my board failing.
    Does it light the led in the diagnostic screen when you pass a screw driver under it?
    is there voltage present on the signal wire at the mx3660? when the light lights and does it go away when the light goes out?
    Feb 2014
    21
    Thank you for replying, I just fixed this last night, I had one of the wires in the wrong input, that`s fixed now & everything is 100%, thanks again for your help!
  1. A different Limit Switch Problem
    By bamabones3 in forum Chinese Machines
    Last Post: 02-23-2012, 08:00 PM
  2. Limit switch problem?
    By Bill Gillen in forum Centroid CNC Control Products
    Last Post: 05-08-2008, 06:02 PM
  3. Limit Switch Problem
    By tz1238 in forum Machines running Mach Software
    Last Post: 02-07-2008, 11:00 PM
  4. Limit switch problem
    By jimini in forum Mach Software (ArtSoft software)
    Last Post: 09-18-2007, 02:49 AM
  5. Problem With IH Limit Switch.
    By Willyb in forum Charter Oak Automation Support Forum
    Last Post: 11-07-2005, 12:17 AM
