586,055 active members*
4,376 visitors online*
    May 2019
    27
    Help with UB1 Spindle Control for PM 30MV
    The UCCNC UB1 already have a PWM, can I use that to get 0-5VDC? Is there a way to bypass the AnaSpeed circuit? There is no AC voltage. All I have is the 24VDC and 5VDC from the UB1 and 5VDC from the spindle controller. Do I have to go DC(from spindle controller) to AC(AnaSpeed) back to DC(Lowpass Filter)?
    Re: Help with UB1 Spindle Control for PM 30MV
    If you supply 5V to AH1, the UB1 will output 0-5V.
    There is a slight voltage drop though, so you need to provide slightly more than 5V to get a full 5V out.
    You could also supply 10-12V to AH1, and adjust the PWM Max % to reduce the output to 5V, by setting it to roughly 50%.
    May 2019
    27
    If I put 5VDC on AH1 won't AO1 be AC?
    No, there is no AC voltage. It'll be 0-5V DC voltage.
    May 2019
    27
    Guess I read the manual wrong. Thanks for your help!
  1. Planning PM-30MV Conversion
    By Landmark573 in forum Benchtop Machines
    Last Post: 07-01-2019, 03:06 PM
  2. PM-30MV-L CNC conversion
    By AVRnj in forum Benchtop Machines
    Last Post: 05-03-2015, 12:31 PM
  3. PM-30MV or G0704 for CNC Conversion
    By cowanrg in forum Benchtop Machines
    Last Post: 02-19-2014, 03:27 AM
  4. PM-30MV CNC Conversion
    By comtech in forum Benchtop Machines
    Last Post: 02-14-2013, 08:13 PM
  5. A few questions on the PM-30MV.
    By Qayok in forum Benchtop Machines
    Last Post: 03-21-2012, 12:04 AM
