586,391 active members*
3,130 visitors online*
Results 1 to 6 of 6
    Aug 2019
    5
    Calculate SQ param. Mazatrol T1 Masak QT20
    Hello.
    Just got a "new" lathe.
    Parameters was lost due to a bad battery.
    I have put in all parameters from the book.
    I can write programs and run them. BUT I cannot get the chuck to move its jaws with the pedals. It´s a hydraulic chuck.
    When I actuate the valves manually it moves fine. The valves does not get any voltage when i use the pedals.
    I think the SQ parameter is wrong, but I have searched all over and cannot find a value that works. With 512 I can run programs fine. With some other values I get errors when pressing cyclestart.
    I have tested most of theese combinations 1, 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024, 2048, 4096, 8192, 16384, 32768
    Can anyone help me?
    /Andreas
    email: [email protected]
    Aug 2019
    5
    Re: Calculate SQ param. Mazatrol T1 Masak QT20
    With SQ 512 I can get the chuck to open with an M06 line, but not close.
    The in/out switch on the back of the machine seems to be backwards, I have to have it on inside clamping to be able o start a program with the aws closed.
    Footpedals still does not work.
    Aug 2019
    5
    Now I got M07 working, and it holds pressure. But still no footswitch....
    Sep 2012
    217
    Have you checked that the foot switch is actually working? Might be just a faulty switch or wiring may have been damaged in transit
    Regards Bob
    Aug 2019
    5
    Quote Originally Posted by sudsy View Post
    The switches works fine and I have 24v to the concacts.
    Still havent found where the wires goes in the cabinett....
    Aug 2019
    5
    Solved!
    A friendly member sent over a parameterlist and SQ 18576 was the right one for me.
  1. Mazak QT20 Mazatrol T-Plus Error 311
    By wolfy11511 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-26-2016, 02:44 PM
  2. MASAK SLANT TURN 30 TROUBLE
    By peloflex in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-28-2016, 03:21 AM
  3. Masak nexus410-A servo parameters
    By andrade in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-07-2013, 05:28 AM
  4. Mazatrol T-1 QT20 ?'s Please help
    By halfafinger in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-02-2012, 08:54 AM
  5. how I can calculate the overpressureHi all,Could you tell me how I can calculate the
    By Lafaso870 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-08-2010, 10:38 AM
