586,371 active members*
3,617 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Computer won't wake up. GGrrrr...
Results 1 to 12 of 12
    Nov 2013
    402
    I have a little problem this morning, seeking help.
    My 770 has been "asleep" for about two weeks, and now she won't wake up.
    I turned on the Computer Power switch on the front panel, but the Screen is stuck on the TORMACH Logo screen.
    The PC Tower green light is on, but the small red light is off, and the red Computer light on the front panel is also off.
    Software isn't loading?
    I tried shutting it down, waiting, then restarted it.... No luck.
    Screen is still stuck on the TORMACH Logo.
    Pathpilot won't load.
    HELP!!
    Nov 2013
    402
    Re: Computer won't wake up. GGrrrr...
    I hit the F2 button, and got this:
    673
    looks like crashy time for the hard disk. prolly have to reinstall
    Nov 2012
    591
    Honestly, you might need to put in a new hard drive, and THEN re-install.
    Tormach doesn't make it very easy, because they ship the drive pre-installed.
    Perhaps you can buy the $20 USB "upgrade" to get an image to install off of? (Although I don't know if this requires a 1.9 image to get going.)
    Btw: Are there copyrighted files (not under GPL/MIT/etc) in the intalled PathPilot system? Or would it be okay for someone to make an image of a working installation, and put it up for download somewhere?
    Nov 2013
    402
    Fixed it!
    I had to manually type in.. fsck
    That re-booted the hard drive.
    Everything's working now.
    Apparently it's a common hard drive error caused by shutting down the computer incorrectly?
    A Linux issue?
    Funny, because I always use the same protocol for shutting down the PC. (Exit, E-Stop, Shut-Down, then Power switch off.. as recommended)
    Maybe I should just leave the PC on for good, from now on.
    Feb 2008
    644
    Quote Originally Posted by RussMachine View Post
    Fixed it!
    A Linux issue?
    The error suggests that your TOD clock forgot the time (your CMOS battery is bad/marginal on your PC so 2 weeks load on the battery made the TOD chip forget the time)
    Nov 2012
    591
    Linux file systems generally are robust against turning off the power whenever. Just like modern Windows (NTFS) but unlike USB sticks and old windows (FAT.)
    Having to run "fsck" is not normal for booting, even if you turned off the power "hard" before that. Something "bad" happened to cause that to be required. It may be that that "bad" thing won't come back, and you'll be fine, but if it happens again, you might want to look into what it is, because you will be losing data at some point.
    Sep 2005
    1740
    Simple. Don't enable the Sleep Mode. Shut the computer down 100% or leave it on 100% (not connected to the internet).
    Linux is not the cure all for every user mistake. I have been using and building computers since 1980 or so. Tried Linux a couple times, but the programs I Need to use are either Apple or PC based.
    Nov 2013
    402
    Well, I took the controller to my local computer repair guy to replace the CMOS battery and update the TOD clock, as well as backup the hard drive.
    I tried getting to the battery myself, but in this controller it is a royal PAIN IN THE ASS to get to it! So I decided to let the pro work on it.
    Bad news = the CMOS battery is a 2-Prong gimmick, and it has to be ordered.
    Looks like my mill will be down for another week.
    Maybe I should just buy a brand-new controller with all of the latest Bells & Whistles?
    That's my next move if this fix-it job doesn't work. :devious:
    Jan 2018
    1516
    That's the trouble with manufacturer official, properly made equipment. There's stitch-ups all over them so you have to go to them for overpriced spares and not cheaper 3rd party.
    Nov 2012
    591
    I find the computer on mine to be a fairly standard low-cost PC.
    The "two prong battery" is used in a variety of OEM motherboards. (There's several kinds, either fixed on the motherboard or even using a small wire welded to the battery ...)
    Personally, I'd just bust out the soldering iron and have that taken care of, but that's of course a personal preference and willingness to much with the computery bits :-)
    Aug 2018
    If I may make a recommendation, when I bought my 1100-3 machine second hand I didn't want to trust the HDD so I cloned the hard drive on a SSD and the benefits are great: much faster boot time and less prone to vibration issues.
    SSD are cheap now, you need the SATA kind for and old pathpilot controller
    you can clone drive without a computer providing that the target HDD has a capacity equal or greater as the source with something like that:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    hope this helps
  1. Replies: 0
    Last Post: 01-20-2018, 04:17 AM
  2. Wake on LAN function for a laptop using a Galil DMC-4080
    By Jim Dawson in forum Computers / Desktops / Networking
    Last Post: 12-12-2016, 08:06 PM
  3. Help me wake up my operators
    By borgcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-23-2008, 09:42 PM
  4. Help me wake up my operators
    By borgcnc in forum CNC Machine Related Electronics
    Last Post: 10-22-2008, 05:26 PM
  5. 2AM: I wonder if the table saw will wake the kids...
    By 10bulls in forum CNC Wood Router Project Log
    Last Post: 07-16-2007, 09:17 PM
