586,080 active members*
3,485 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > When switching tools on a Haas is it necessary to change all of the tool settings ?
    May 2013
    167
    I have a haas super mini mill, and when I change tools I go into the machines control panel and change all of the new settings ( tool length, diameter, flute qnty, and tool type )
    Other than the tool length, are the rest of the settings just for reference?
    In other words can I just get away with changing the tool length field?
    I'm using Fusion 360 to create all of my code, so all of my tool info is being managed on that end of things.
    Kent
    15362
    Re: When switching tools on a Haas is it necessary to change all of the tool settings
    Quote Originally Posted by kentdesautel13 View Post
    Kent
    Yes you only need to be changing the Tool length offset
    Now if you have a tool that you are using with tool comp then that tool will need it's diameter entered
    Mactec54
  1. Replies: 3
    Last Post: 03-14-2024, 03:56 PM
  2. haas vf2 tools jam up on tool change
    By allenp in forum Haas Mills
    Last Post: 07-21-2016, 06:05 PM
  3. Replies: 8
    Last Post: 11-03-2014, 04:28 PM
  4. ???Dropping Tools during tool change???
    By eddyindo in forum Daewoo/Doosan
    Last Post: 06-11-2013, 04:34 AM
  5. Any G-codes that can change HAAS settings?
    By jbcourt in forum G-Code Programing
    Last Post: 11-01-2011, 04:17 PM
