586,052 active members*
4,157 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 3016 won't brake spindle to stop
    Nov 2009
    23
    When turning off the spindle, the braking system is no longer working. I replaced the re-gen resistor as that was what FADALCNC.com told me would fix it. Nope.
    When turning off, it free spins, then lurches like you hit the brakes, but only for a half second, then free spins some more and lurches slower, and does that about 3-4 times and eventually free spins to a stop.
    It's a DC, 1993 machine with an Advanced Motion Controls spindle driver.
    Any suggestions would be awesome.
    thanks
    Jon
    Re: Fadal 3016 won't brake spindle to stop
    You have (had) a problem with DC braking inside inverter. I hope you have resolved this problem.
    In case of any service question - you may contact me.
    Nov 2009
    23
    No, I have not been able to resolve this problem. I changed out the re-gen resistor but that didn't help.
    What is the next step? Finding service men that will work on these is getting harder to do.
    Apr 2014
    345
    Look for a inv-30 from fadal cnc it should fix the issue. One thing to note though is fadal cnc nor glentek will help you installing it but it’s really simple. Most of the techs didn’t even know such a thing exists and some of them couldn’t even understand how a glentek board would work on a amc drive. But I tried it and after the first one not working at all the second one worked perfectly.
    Jan 2015
    417
    if your going to use their search engine it will be inv-0030
  1. WTB Fadal VMC-3016 or VMC-15
    By Recoil6 in forum Fadal
    Last Post: 06-14-2018, 07:18 AM
  2. spindle will not stop fadal 4020
    By choppermex in forum Fadal
    Last Post: 06-17-2016, 09:59 AM
  3. VMC 3016 Spindle would not stop
    By S Woods in forum Fadal
    Last Post: 06-30-2010, 06:27 PM
  4. Bridgeport spindle brake - how fast should it stop?
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 07-01-2007, 07:11 AM
  5. Spindle/e-stop/grn Light/brake Wiring
    By TPMX in forum Bridgeport / Hardinge Mills
    Last Post: 05-06-2007, 02:46 AM
