586,058 active members*
3,448 visitors online*
Results 1 to 18 of 18
    Apr 2018
    24
    I need a manual for VFD ZONCN NZ200
    Hello everyone.
    I need a manual for VFD ZONCN NZ200.
    I wrote to the supplier. I wrote to the manufacturer and no one answered me.
    Can you help me please?
    Thanks Jirka
    15362
    Re: I need a manual for VFD ZONCN NZ200
    Quote Originally Posted by jirkamm View Post
    Hello everyone.
    Thanks Jirka
    What is the manufactures name
    Mactec54
    Apr 2018
    24
    ZONCN
    15362
    ZONCN
    What do you need to know about it I don't have the manual but may be able to help
    Mactec54
    Apr 2018
    24
    Hello.
    I need to set - "device error" for relay output 1.
    Set to relay output 2 - "device on" output
    For analog output I need to set - output "Current frequency" - 0-10V.
    But it probably doesn't have an analog VDF output.
    Thank you
    Apr 2018
    24
    Next, I need to set to control the pump power with an external potentiometer.
    15362
    I need a clear photo of the low voltage terminals
    And no you would not use any of the relay output for a Pot
    Tell me what your VFD is being used for and what it is driving
    Mactec54
    Aug 2019
    31
    Hello everyone.
    Thanks Jirka
    Hi, I have one, how to send it to you?
    Apr 2018
    24
    Hi.
    "And no you would not use any of the relay output for a Pot" (I don't understand this sentence)
    VFD is used to control the vacuum pump power for the vacuum table. I need to adjust the power with a potentiometer. When milling holes and grooves I need to increase performance. I meant to connect the potentiometer and pressure sensor in series.
    15362
    Hi.
    Not a very good photo the +10 AVI and Ground Terminals are what your Pot connects to AVI to the center Pot connection there is also a Jumper or switch that needs to be set J2 to AVI it is beside the terminal block
    There may be a Parameter to set also
    Mactec54
    15362
    Quote Originally Posted by CNCINDUSTRY View Post
    You can attach it here, open a post, go to Advanced scroll down and attach a PDF File
    Mactec54
    Aug 2019
    31
    Hi.
    Do you need to controll the VFD dynamically?Then you need a controller which has analog input and output module. Such as PLC.
    The potentiometer and pressure sensor connect to the controller's input terminals, and its output terminal connect to the VFD‘s analog input terminals.
    Aug 2019
    31
    Awful,size limited.
    Do you need the wiring diagrams? Maybe later.
    Apr 2018
    24
    Awful,size limited.
    Please send it to [email protected]. Max. 20Mb.
    Jirka
    Apr 2018
    24
    Yes. I need to dynamically. I told the supplier that I needed it this way. The supplier said - ok.
    I see that I can throw away the VFD.
    15362
    Your VFD is not different from any other, I'm sure you could do what is needed if you get creative, your sensor would be controlled from your machine control and would output a voltage change to adjust the VFD Drives motor RPM as needed not hard to do at all
    Mactec54
    Apr 2018
    24
    It is true. I will have linuxcnc and Beckhoff EL3064 and EL4004 there. That could work.
    Good idea.
    Oct 2020
    HiGood Day! I need the manual also, would it be possible for you to share it to me?
  1. Replies: 0
    Last Post: 08-06-2018, 05:45 AM
  2. Colchester 3000l maintenance manual, parts manual
    By jaqn in forum Colchester Tornado lathes
    Last Post: 11-17-2017, 02:41 PM
  3. Replies: 0
    Last Post: 03-18-2016, 10:55 PM
  4. For Sale Complete Maho MH 600E Manual, + Philips 432 Programming Manual
    By HKgunslinger in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-08-2012, 08:09 AM
  5. Replies: 0
    Last Post: 06-17-2010, 12:59 PM
