586,516 active members*
3,363 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Holding brake needed on a 4/5th axis when using a harmonic drive?
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Oct 2016
    12
    Re: Holding brake needed on a 4/5th axis when using a harmonic drive?
    Quote Originally Posted by spumco View Post
    Will it work? Yep. And the OP, if this thing ever gets built, will work out what the actual limitations of using it are.
    Well...
    Pic is just after I poured the epoxy a couple days ago. It's starting to cool off here in Ohio so I hurried up and got the frame together so I could get the epoxy down before winter. Checked it today with my 36" straight edge and except for the weld seams where the epoxy is a little deeper and shrunk more, I couldn't get a 0.0015" feeler gauge to go so I am pretty happy. Gonna bring home my 0.0005" level home from work tomorrow and see where I'm at.
    I should really start a build log since this isn't really the right sub-forum for this.
  2. #22
    May 2016
    316
    Did you say Ohio?
    Care to share what part?
  3. #23
    Oct 2016
    12
    Lancaster
  4. #24
    May 2016
    316
    Quote Originally Posted by shinji2k View Post
    Lancaster
    Ahh. Close, but not close enough to Ashtabula for a mid-week garage night.
  5. #25
    Oct 2016
    12
    Yeah its a bit far to drive for, admittedly, not much to see.
Page 2 of 2 12
  1. Is a Harmonic Drive best solution for a 4th axis?
    By bogiestl in forum Benchtop Machines
    Last Post: 09-23-2019, 06:49 PM
  2. Home Made 4th Axis with Harmonic Drive Unit!
    By widgitmaster in forum Benchtop Machines
    Last Post: 08-27-2017, 03:16 AM
  3. Help! Harmonic Drive 4th Axis Troubles
    By BanduraMaker in forum Linear and Rotary Motion
    Last Post: 12-22-2016, 11:06 AM
  4. Harmonic Drive 4th axis - PEU
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 04-27-2014, 04:33 AM
  5. Harmonic drive 4th axis for the X2
    By scubaben in forum Benchtop Machines
    Last Post: 03-04-2012, 07:51 PM
