586,080 active members*
3,655 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati milling machine
    I have a problem in my Cincinnati milling machine
    That after it works
    It gave me "power supply fault"
    And machine is stopped
    Oct 2016
    106
    Re: Cincinnati milling machine
    Check if you have around 310V from power supply psr4, I assume you have kollmorgen drive.
    Sent from my D5803 using Tapatalk
    Dec 2006
    584
    You have a bad control power supply if you have a 2100 control. The problem is not in the PSR4 of your drives.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    thanks for your reply
    i will check and update you soon
    could you explain to me more about
    wait your reply
  1. Cincinnati milacron arrow 750 milling machine
    By harvey wallbang in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-27-2014, 06:54 PM
  2. cincinnati arrow 500 machine power on issues
    By lineborn in forum Cincinnati CNC
    Last Post: 04-09-2013, 12:52 PM
  3. ANTIQUE Cincinnati hyspeed tapping machine #28
    By archangel in forum Uncategorised MetalWorking Machines
    Last Post: 05-04-2008, 05:57 PM
