586,062 active members*
4,884 visitors online*
    How to Login 10.0.0.1 IP Address?
    The manufacturer of the router set some credential to access 10.0.0.0.1 IP address with certain password and username that's allow only specific user can access their private network and nobody can not conflict or try to access your network. This private IP address has authenticated the users to disallows unauthorized change to its settings also.
    What we do when 10.0.0.1 username or password forget. Then come along with our blog and you can try your luck with the help of our complete list of most of the popular brands and models of gateways and routers.
    Click here to know more https://www.10-0-0-0-1.tech/10-0-0-1/
    <a href="https://www.10-0-0-0-1.tech/10-0-0-1/10-0-0-0-1.tech" target="_blank">10.0.0.1</a><br />
    Jul 2020
    Re: How to Login 10.0.0.1 IP Address?
    Quote Originally Posted by AMorrison View Post
    Thanks for your feedback, i tried it but it didn’t work for my router, i think my router have another address page, i need to restore it because i can’t connect any device with it i don’t know what happened to it exactly, i googled about it so much also watched many videos on youtube but none was helpful, i end up ask my friend help he’s IT guy he has a long experience with connections and internet and ask me to login to configuration router page using 192.168.0.1 and sent me this https://19216811ip.host/192-168-0-1/ to help me out but it does not work either.
    i have same problem, and this link was helpful, thanks
    Nov 2018
    I have a Deckel DMU 70 V milling machine that you backed up in 2001-02-21.
    I need parameter 311 password to use Dnc Plus network facilities.
    If you can help me.
    Feb 2021
    The 10.0.0.0.1 is actually a mis-typed wrong IP address that someone types when they add an extra zero in the URL, ideally the correct keyword is 10.0.0.1 and is used as the default gateway address for Xfinity router admin settings and few other router brands. This IP address is also referred to as a router IP which falls under private Class -A IP address range.
