586,060 active members*
4,185 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Page to view VS* variables
Results 1 to 19 of 19
    Sep 2015
    26
    Question Page to view VS* variables
    Does anyone know of a page or way to view VS* variables without having to store them in a VC* variable?
    Apr 2009
    1262
    Re: Page to view VS* variables
    There is not a way to display system variables without transferring them to common variables. That being said, some of them have their won display pages such as zero set variables, Zero Shift variables, tool offsets, tool radius etc.. Which system variables are you trying to display and why? We may be able to help you depending on what you are trying to accomplish.
    Best regards,
    Experience is what you get just after you needed it.
    Sep 2015
    26
    The system used common variables Eg VS1 to VS200
    Apr 2009
    1262
    Please clarify.
    Sep 2015
    26
    We have HMC mill's with p200 and p300 controls. Some of the variables i use are the common variables that are there for system to use. I guess like system global variables.
    Code:
    OTCHG (START CHANGE TOOLS)
    CALL OANTL (FIND TOOL NUMBERS)
    IF [PNT NE EMPTY] N10
    PNT=0
    N10IF [VS200 NE PAT] N50
    IF [VS199 EQ PNT] NRTS
    N50IF [VS199 EQ 0] N100
    IF [VS199 EQ PAT] N100
    M64
    N100CALL ONGPS PAT=PAT (CHECK NG TOOL PAUSE)
    T=PAT M6
    N150IF [PNT EQ 0] N200
    IF [VTLD3[PNT] GT 10] N200
    T=PNT
    N200
    NRTS RTS
    There just like common variables but there used by aftermarket addons so they don't have to use up common (VC) variables to store things.
    There nice in some ways because you can't change them from the common variables page. We used to have a guy that would write zero's to the common variables every night because he said he didn't like that they didn't all match.
    When he did that the machine would alarm out because my subprograms would lose there data.
    Jun 2015
    4154
    hy rdhoggattjr
    this code works on osp300L :
    Code:
        NOEX V1    =      0
    $        VS099 = 111111
    $        VS99  = 222222
    $        V1    =  VS099 ( v1 will be 222222 )
    VS* may be sometimes like common variables, but it is indeed much more :
    ... VSET : is like an instruction, allowing to declare variables inside sdf
    ... VCAC* : is like a boolean, returning spindle state : S or C mode
    ... VS27, VS28, VS29, VS30 : is like a common variables, inside renishaw probing macros
    - system variables are linked with the controller; they are initialized by it
    - common variables are not linked with the controller; they are not initialized by it, but by the user / programmer
    when you use VS* like that, you are entering an area that may be protected, so you have to be sure:
    ... that the controller is not using those syntaxes, or
    that the controller is using those syntaxes, but the way that you are using them is not interfering with the controller
    to avoid such potential dangerous situations, then use common variables, or local variables ( they can no be changed from an input panel )
    your program has a few types of variables :
    ... system variables VTLD3
    ... local variables PAT , PNT
    ... off limit ( system or local ) : VS199 , VS200
    if possible, use a single type of variable
    pls be aware:
    ... about PAT , PNT : until a while ago, it was not allowed to use local variables that begin with P
    ... about VS199, VS30 : is not allowed to use local variables that begin with V
    that code that you shared, is a lucky hit, or created by someone who knows the interferences
    system variables are global
    that seems to be a tool change macro, that uses also tool groups ; why do you need to lock the variables, so to make it work ? why do you can not rely on common variables ?
    whatever exception exists, it must be handled by the code, and the code itself should stand-alone, whatever the common variables values are ...
    there is an exception case with your code, so you wish to avoid common variables : what is that exception ?
    also, somewhere, i believe you lose traking the data, so you need to read the VS* value / kindly
    Sep 2015
    26
    Quote Originally Posted by deadlykitten View Post
    hy rdhoggattjr
    Code:
        NOEX V1    =      0
    $        VS099 = 111111
    $        VS99  = 222222
    VS* is like common variables, but also much more :
    your program has 2 types of variables : system variables ( VS*, V**** ) and local variables ( PAT , PNT ); if possible, use a single type of variables
    pls be aware, about PAT , PNT : until a while ago, it was not allowed to use local variables that begin with P
    also, somewhere, you lose traking the data, so you need to read the VS* value / kindly
    It is a tool change macro. This macro is about three levels in, but in an older version of my subs I use to store current and next tool numbers in VC variables and they would set them to zero.
    That's why I switched to using VS variables for some things.
    Before I use any I search through both the Renishaw probing macros and the Okuma probing macros to make sure that there not using them.
    Jun 2015
    4154
    if the program will be there for :
    ... a while, i store actual and next, inside the program
    ... a short time, i no longer bother with the next tool ( no more prestaging tools )
    if you have 10+ tools, you will edit 10 variables ? or 10 actuals + 10 next, and how you manage it inside the program ?
    why don't you edit the program ? kindly
    Sep 2015
    26
    We use the variables to store characteristics about the tools, like default tool lengths, number of flutes, tip radius, diameters and more. It's all used to run auto tool measurement and tool breakage detection on our pallet system machines. They get updated through txt files at tool changes.
    Jun 2015
    4154
    okey, so there is more then a tool change macro
    tool length & diameter : good when measuring
    radius : for comp codes
    please, where/how do you use the "number of flutes" characteristic ? and what other characteristics are you using ? and what type of tool measuring system are you using ?
    please, will you share such a file ?
    now, back to you : if you send data, in order to auto-measure or detect broken tools, why do you still need to check the vs** variable value ? i mean, is like you are one step ahead, with tool preparation/measure/detect, but you are one step behind with the tool change macro ...
    i am sorry, i can not help you : you can not check the system variable value directly ( unless you store it in a file, or record it inside a common variable ), and i also can not sugest you a solution, or an alternative, because i can't locate the problem
    i believe that there is something that you can speed up, so to avoid checking the vs**, but i need more details / kindly
    Sep 2015
    26
    It was just for faster debugging of the macros.
    I use number of flutes for measuring face mills and inserted tools that I don't want to spin to find high flutes. I also need flute angle to spindle orientation for tool alignment in the holder. The system is a mixture of Okuma and Renishaw macros depending on how it needs to measure the tool.
    Jul 2010
    287
    I believe the answer is no.
    Under gauging results is the only place i'd expect to find them if anywhere, but i haven't looked in that screen for a while and i don't have a mill handy to check.
    That said, there is a note in the gauging manual which states:
    *under "common variables for storing gauging cycle results"*
    "Note that referencing of the common variables indicated above is not allowed in the usual common
    variable reference method. To use the data stored in these common variables, move it to other
    common variables that can be referenced.
    To reference the end face gauging result in the X-axis direction, move the data to VC1, for example,
    by specifying “VC1 = VS29”, then read common variable VC1 in a part program."
    So with at least 99% confidence, the answer is no.
    That said, depending on the control series, i'm not sure if the VS variables are variables which can be read via the API using an app.
    If you can do that, you can read them and post the values to a spreadsheet looking screen to display them, think AutoComp. Though i'm not an app writer or software programmer.
    Another stop gap, depending on the control series, is that you can store VS variables to local variables.
    Local variables can be displayed on some of the newer series of OSP controls.
    Therefore you'd have:
    NUM1=VS2
    NUM2=VS5
    and though you wouldn't be able to display VS2 or VS5 directly and real time, you could view it sort of using local variables.
    Hope that answers that for ya.
    Jun 2015
    4154
    if you wish to debug the macro, simply write down the values that you wish; try this, it separates the values with tabs, so you can paste the content inside *.xls :
    Code:
    ODD ( data dump ) ( call it from within the tool change macro, or close to it )
        FWRITC data.txt;A
        NOEX PUT VS200 PUT '    ' PUT VS199 PUT '' PUT PAT PUT '' PUT PNT
        WRITE C
        CLOSE C
    RTS
    i hope it helps
    i was a bit confused ... i believed that you wish to use common variables all the time, so to input actual and next tool, from the cnc panel; now, that you only wish to debug, it makes more sense
    however, even so, i believe that you could use only common variables, and make the program work, even if someone edits the common variables from the panel : it should work, as long as you initialize the variables from within the program; well, if someone changes them during a tool change sequence, then, you know, bad luck but still, this does not happen often ...
    please, can you explain this a bit ? for example, if you have a tool dia80, z6, you will somehow measure the angle between the tool and the toolholder, so to know the orientation angle of the spindle, so to measure it directly at it's highest point ?
    please, explain a bit more
    also, from that file : what is 1337, FL , ROT , TI , BRLI , B , S , R , RD1 , RD2 , RD3 ? kindly
    Sep 2015
    26
    We have some large tools (8" reamers and 6" facemills) that we don't spin when we measure them because they are that big. So the machine takes the number of flutes and rotation of the body of the face mill to check each flute for the highest one and uses that as the length offset.
    machine number, number of flutes, rotation of flutes, cut time before auto measurement, amount of tool breakage before tool is considered broke, check for breakage, spin tool during measurement, swap tool on tool life time out, and RD1, RD2 and RD3 are redundant tools that it can swap too.
    Jun 2015
    4154
    hy, is it ok for you to use the fwritc, so to debug your soubroutine ? do you need something else ? you could also use :
    ... local variables, and check a table that displayes them; pls check post 27 : https://www.cnczone.com/forums/okuma...variables.html
    ... common variables, check their value, and when is all ok, switch back to VS*
    nice job did you looked into the msb files ?
    however, when you use a custom name variable, a custom syntax, there are restrictions :
    ... no function names, no comparison or boolean operators
    ... no extended addres characters
    ... no reserved local variable words
    ... no local variables that begin with O, N or V
    * possibly others; if you are intersted, check the list below
    if somehow you enter inside a conflict area, you should not worry as long as you know that you don't interfere with the control; for example, i have messed with the oo30 inside the msb, and some VS variables, also inside the msb file, so to ' tune ' a few things
    8" reamer ? is it a bt30 machine ? if i may, is it going inside a blind, or a through hole ? and why don't you use a simpler tool, like an excentric ?
    so tools with flutes are aligned, rotary, in respect to spindle orientation ... nice job
    i guess you are using a renishaw touch setter, not a fancy laser ...
    what about avoiding in machine-measurement ? have you considered that ? you could tranfer offset values inside the machine, and only measure, in order to detect if it's broken; like this, you could avoid the in-machine measuring time ... or you wish to target directly a finishing dimension ? you don't probe, and recut ? only one cut, and that's it ? just asking ...
    kindly
    Code:
    1A
    1B
    2A
    2B
    AA
    AB
    ABS
    ACOS
    AG
    AN
    AND
    ARC
    ASIN
    AT
    AT
    ATAN
    ATAN2
    BA
    BC
    BCD
    BHC
    BIN
    BOUNS
    BR
    BT
    CALL
    CAMCV
    CASCME
    CASCTL
    CB
    CC
    CD
    CF
    CHD
    CHFC
    CHFR
    CL
    CLEAR
    CLOSE
    CONEI
    CONEO
    COPY
    COPYE
    COS
    CP
    CQ
    CR
    CT
    DA
    DA
    DB
    DB
    DC
    DEF
    DELETE
    DFIX
    DFUP
    DGRDX
    DGRDY
    DO
    DRAW
    DROUND
    DS
    EMPTY
    END
    EOR
    EQ
    FA
    FA
    FB
    FB
    FC
    FI
    FIX
    FMILF
    FMILR
    FOPENA
    FOPENB
    FUP
    FW
    FWRITC
    GE
    GET
    GOTO
    GRCI
    GRCV
    GRDX
    GRDY
    GRER
    GROF
    GRON
    GRSK
    GRST
    GT
    HA
    HA
    HB
    HC
    HI
    HJ
    HK
    HORN
    HP
    HS
    HS
    IA
    IB
    IF
    KA
    KA
    KB
    KB
    KW
    LA
    LAA
    LB
    LCONI
    LCONO
    LD
    LE
    LK
    LMV
    LMW
    LPRINT
    LT
    LW
    MD
    MG
    MGS
    MITCAN
    MN
    MOBOR
    MOD
    MODIN
    MODOUT
    MODRL
    MODSF
    MOEND
    MOPLD
    MOREM
    MOTAP
    MSG
    MT
    MTM
    MTS
    NE
    NOT
    NP
    OF
    OG
    OR
    OS
    PA
    PCIR
    PMIL
    PMILR
    PREG
    PRINT
    PRINTF
    PRMDI
    PRMDO
    PRSOL
    PTANXT
    PTPRET
    PTRETT
    PUT
    PW
    PX
    PXD
    PXE
    PXF
    PZ
    PZD
    PZE
    PZF
    QA
    QA
    QB
    QC
    QD
    RA
    RB
    RC
    RCIRI
    RCIRO
    READ
    RGEND
    RH
    RH
    RI
    RJ
    RLDPN
    RM
    RMILI
    RMILO
    ROUND
    RP
    RS
    RSQCO
    RSQRI
    RSQRO
    RSTRT
    RT
    RT
    RTI
    RTMCR
    RTMDI
    RTS
    RW
    SA
    SAVE
    SB
    SB
    SC
    SC
    SCALL
    SCALLE
    SCALLS
    SCALLSE
    SCRIPT
    SIN
    SLOAD
    SP
    SPHRI
    SPHRO
    SPRINT
    SPRINTF
    SQRT
    SQRX
    SQRY
    SS
    SYNC
    TA
    TAN
    TANXT
    TAPR
    TB
    TC
    TD
    TDG
    TE
    TFA
    TFB
    TFC
    TFP
    TFQ
    TFR
    TG
    TG
    TH
    THEN
    TL
    TLCO
    TLFOFF
    TLFON
    TLFR
    TLOK
    TM
    TN
    TN
    TP
    TPRET
    TR
    TRDL
    TRDT
    TRETT
    TS
    TSG
    TT
    TW
    UA
    UB
    WA
    WB
    WHILE
    WP
    WRITE
    WW
    XA
    XB
    XD
    XE
    XF
    XS
    ZA
    ZB
    ZD
    ZE
    ZF
    Sep 2015
    26
    Thank you for the info
    I came across that thread in my search. interesting read. I don't deal in lathes much so it was neat to see some of the diffences between the two.
    Yeah
    I have done the same, but I saved the msb macros to another file and changed "OO30" and so on to "OT30" as to not mess with the factory msb's
    CAT50. Through hole in cast iron. We moved the parts from another machine that was giving fits and didn't want to retool.
    Yes. From what I have heard lasers can mismeasure if there is lint or even coolant on the tool.
    what about avoiding in machine-measurement ? have you considered that ? you could tranfer offset values inside the machine, and only measure, in order to detect if it's broken; like this, you could avoid the in-machine measuring time ... or you wish to target directly a finishing dimension ? you don't probe, and recut ? only one cut, and that's it ? just asking …
    The machine remeasures at the same time as checking for breakage if the tool has enough cut time on it, otherwise it just checks if it is broke.
    Jun 2015
    4154
    please, what is the difference between ot30 and oo30 ? this ot30, did you stored it inside a lib file, or inside a msb file ? kindly
    Sep 2015
    26
    I made it to where the tool can spin at recommended speeds and feeds in the Renishaw manual for our probes. But I later found out there is a way to make it spin with standard Okuma macros. https://www.cnczone.com/forums/okuma...ubprogram.html
    Its's in an SSB file.
    Jun 2015
    4154
    hy, i am dealing these days with local variables, and i remembered this thread
    VS are local variables ( flashed on reset ), array type : for example, VS00001 = 1 and VS1 = 1 will target same variable, while VS[1] won't work; being an array type, means that the variable is created at system power on, by default, thus VS should never be empty
    if you wish, i have some programs for reseting, backing up, etc ... onestly, i have some days when i hate to see a common variable <>0; yeah, i know ...
    also, use this to boost your code; more stuff can be done / kindly
    Code:
    OTCHG (remove comments)
    CALL OANTL
    NOEX PNT=0
    M64
    N100CALL ONGPS PAT=PAT (*1)
    T=PAT M6
    N150IF [PNT EQ 0] NRTS
    IF [VTLD3[PNT] GT 10] NRTS
    T=PNT
    NRTS RTS
    (*1 maybe it does not matter now, but PAT=PAT is not required on lathes, because local
    variables, once created, are available on all following/child nesting levels )
  1. Replies: 0
    Last Post: 12-26-2017, 08:13 AM
  2. how do i view variables in VB script?
    By kjl-pdx in forum Mach Wizards, Macros, & Addons
    Last Post: 01-20-2014, 04:18 AM
  3. g-view and wcs for HBM
    By dcutler35 in forum Mastercam
    Last Post: 06-08-2012, 08:23 AM
  4. Arrow, Page Up & Page Down Keys - Rhino Video Tutorial
    By Robert Schutz in forum Rhino 3D
    Last Post: 04-25-2006, 04:09 PM
  5. NC reading tool length from offset page, not data page..?
    By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-21-2006, 11:07 PM
