586,077 active members*
3,738 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > what kind of turret is on this old Stand-Modern lathe?
    Feb 2006
    49
    Can someone tell me what kind of turret is on this old Stand-Modern lathe? I need to buy a boring bar tool holder for it but do not know what type of turret this is and can not pick out a compatible tool holder. It is 9.75 in. in diameter. It is circular and does NOT have flats on the circumference. Id and pics below.
    STANDARD-MODERN LATHES
    KESTREL ????IN? ???LS INC.
    MANUFACTURED IN NORTH ???RICA
    Lathe Sn: 12171
    Thanks for your help!
    Attachment 425800
    Aug 2019
    339
    Re: what kind of turret is on this old Stand-Modern lathe?
    In your case you need to turn a OD12" stock with an ID9.75" bore then finish the holders on a rotary to accommodate for the bolts (coolant and keyway patterns in a vise).
    Once you got all that debured and bolted on the turret, you then proceed to boring & reaming the 8 holders individually "on the actual lathe they go on" (drill, bore, reamer tools chucked).
    Only then you can source tooling for boring, etc...
    Cheapest/safest/fastest way around your issue I'm afraid. One full day work
  1. baxter / standard modern CNC lathe turret
    By dukie in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2019, 08:54 PM
  2. Modern Adaptation of a WW1 era Yeoman Concrete Lathe
    By AxelFoley in forum Uncategorised MetalWorking Machines
    Last Post: 12-28-2014, 05:59 AM
  3. Fagor 8050T on Standard Modern 20 x 120 lathe
    By Bigbear8291 in forum Fagor Automation
    Last Post: 12-17-2014, 04:38 PM
  4. Converting an old CNC lathe to run on modern computers?
    By blazemaguire in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-19-2011, 05:35 PM
  5. Wiring diagram needed: Standard Modern 13/34 lathe
    By turbostang in forum Vertical Mill, Lathe Project Log
    Last Post: 12-31-2007, 09:34 PM
