586,108 active members*
3,107 visitors online*
Thread: Servos
Results 1 to 16 of 16
    Aug 2005
    58
    Servos
    Anyone running them? What are the pros or cons for this type of machine?
    Dec 2013
    5717
    Re: Servos
    Pro: They work well, no lost steps, generally more speed and power over a wider operating range.
    Con: Cost more than steppers, a bit harder to set up properly.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2018
    362
    Re: Servos
    To add to the "Pro's, they are also much quieter and less prone to resonances at lower speeds. Must say however, the various sounds of steppers can be quite pleasing at times :-)
    To add to the "Con's", a runaway servo can slam against a hard-stop which could be mechanically "damaging" whereas a dead stepper driver/motor combination is just going to "not work".
    On my machine, I chose steppers for compatibility with some existing equipment I had but in hindsight, I should have chosen servos.
    Feb 2005
    829
    Re: Servos
    Could also look into hybrid stepper/servos, like they clearpath units.
    Jan 2016
    78
    Re: Servos
    Am running DMM 750w servos which bolt right into the NEMA34 fittings.
    Lots of torque and super accurate once calibrated thanks to the encoders.
    The setup is much more involved given each servo is 1hp.. mains powered so there’s a lot more electrical controls. Also need to pay attention to good electrical design rules and earthing to avoid noise.
    Really happy now everything is settled in.
    Re: Servos
    Clearpaths are not "hybrids". They are servos. What many call "hybrid" are actually closed loop steppers. Very different from servos.
    Feb 2005
    829
    Re: Servos
    gerry, oh, i must have misunderstood. then they seem to be a very affordable route for servos.
    Aug 2005
    58
    Re: Servos
    To those that have them,
    What do you use to control them? As I understand they would typically have a equivalent to a stepper driver. Do those connect similarly to some of the common electronics / software people use like, parallel ports, UC100, smoothsteppers, Mach, UCCNC?
    I have chance to disassemble some used automation equipment, and wondering if it's worth my while to take the servos.
    Mar 2017
    411
    Re: Servos
    Ditto on the Clearpath SD servo's.
    Integrated drivers/encoders are the bomb.
    Dec 2013
    5717
    Re: Servos
    Quote Originally Posted by infamous_panda View Post
    The Clearpath motors are controlled exactly like a stepper, have the same step & direction input.
    Yes, especially if the drives are included. It's really nice to have a matched motor and drive.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2018
    362
    Re: Servos
    I'll back the Clearpath offerings as well. If/when I was to upgrade my machine I'd go straight to these, they have a drop-in replacement for my steppers.
    Aug 2005
    58
    Re: Servos
    Yeah Clearpath gets a lot of press in the community.
    The parts I'm getting are from Mitsubishi.
    https://us.mitsubishielectric.com/fa...sec-iqf-series
    https://www.mitsubishielectric.com/f..._je/index.html
    They look expensive, and have some really beefy wires going into them. I am just at a loss as to how to get UCCNC and a UC100 to talk to these parts.
    24221
    Re: Servos
    I used to retrofit using Mitsubishi CNC systems previously, the support is great. But a little pricey for DIY.
    BTW, there is none of the large or industrial CNC systems using steppers, all are servo's, in my experience.
    Al.
    Albert E.
    Feb 2008
    644
    Re: Servos
    The drives linked to are generic servos that can work with normal step/dir interfaces (or analog)
    You may need to change their software setup to run in step/direction mode
    Aug 2005
    58
    Quote Originally Posted by PCW_MESA View Post
    Nice! But does setting it up that way lose out on the servos advantage. As I understand it those motors don't have "steps".
    Feb 2008
    644
    Re: Servos
    No, they do not have steps in exactly the same way a step motor has steps, but they
    do have steps in the sense the the encoder resolution is not infinite
    and that the input steps/turn scaling number is limited. That said, good drives like
    Yaskawa (and probably Misubishi) can support MHz step-rates which allow
    very high step/turn ratios so the step/dir interface does not really compromise smoothness
  1. Are Chinese servos a gamble? Servos vs Leadshine closed loop
    By j3dprints in forum Servo Motors / Drives
    Last Post: 01-05-2018, 07:09 AM
  2. Propriatary AC servos into universal AC servos with an encoder swap?
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 05-10-2013, 07:22 PM
  3. which servos
    By mklb in forum Gecko Drives
    Last Post: 05-01-2011, 07:02 PM
  4. where to buy servos
    By mjs79 in forum Servo Motors / Drives
    Last Post: 11-01-2007, 06:59 PM
  5. Can't get servos to run....
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 05-26-2007, 03:52 PM
