586,116 active members*
3,251 visitors online*
Results 1 to 11 of 11
    Aug 2019
    26
    Laser engraving problems
    here are the pictures, the before is how small my text is and when I went to preview or print, it come out huge
    Nov 2012
    1267
    Re: Laser engraving problems
    I don't see a problem. Your text is exactly the same size (96x62mm) in both the program window and the preview window.
    Jan 2008
    940
    is the program bed layout the size of your bed.
    Aug 2019
    26
    so for bugging you so much, but how do I change the size of my bed layout, I have I believe a 700mm x 500mm
    thanks
    Jan 2008
    940
    Open your RDworks and under config there is page settings you can change it there
    Sep 2005
    1740
    Bed size has nothing to do with it. If you set your text size 96mm x 62mm thats what the machine should cut. Unless you have a mm to inches conversion going on or a scaling issue.
    Aug 2019
    26
    not sure if i have mm to inches conversion going on, how do I fix that
    thanks
    - - - Updated - - -
    thanks, can't wait till I get home to try it out
    Sep 2005
    1740
    You say Print or Preview? If you convert to gcode how big does it actually cut, set your machine zero up so it just cuts in the air. If it try's cut or engrave 96 inches instead of 96 mm you will see.
    Most if not all Chinese lasers are set up for mm's. My USA made ULS could do either inches or mm's,
    Aug 2019
    26
    how do I do that?
    thanks
    Jan 2008
    940
    under config para settings DXF MM or Inch
    Sep 2019
    4
    what is the size of attachment image (text1)?
  1. laser engraving problems
    By ninainwa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-26-2019, 03:13 PM
  2. RE: Laser engraving problems
    Last Post: 08-22-2019, 04:49 PM
  3. laser engraving problems
    Last Post: 08-21-2019, 10:48 PM
  4. Having problems with engraving - May need a new laser
    By sports310 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-29-2016, 03:48 AM
  5. laser engraving problems shenhui 350
    By laserdesignlady in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-22-2015, 11:29 AM
