586,036 active members*
3,598 visitors online*
Results 1 to 3 of 3
    Sep 2017
    Acra-Bend Brake Press Help Needed
    I am looking for anyone with an Acra-Bend brake press. Mine is a 2008, 8', 88 ton machine. The PLC battery went dead and the program is gone. It look like all of the machines around that time frame are the same, no matter what size. I would be very interested in a download of your PLC code. Any help would be appreciated.
    Aug 2019
    cybelec dnc 60 durma hap2560 no pos value anay help??
    Sep 2017
    Re: Acra-Bend Brake Press Help Needed
    Bump
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  3. Help needed to truble shoot hydra power press brake model: GHS10010
    By mbarazeen in forum Maintenance DIY Discussion
    Last Post: 06-11-2012, 12:00 PM
  4. Help with press brake manual... Experts needed.
    By rjahr in forum Bending, Forging, Extrusion...
    Last Post: 02-10-2008, 11:41 PM
  5. press brake cam needed
    By cnc metalcraft in forum Bending, Forging, Extrusion...
    Last Post: 10-04-2007, 03:39 AM
