586,116 active members*
3,442 visitors online*
    Jan 2016
    4
    Update DOS application for sending NC files
    Hi
    I am looking to upgrade a DOS application called IBMCNC which is used to send NC files to an old controller. Is there a modern application that will run on Windows 10 that can transfer files over serial connections to old controllers.
    Apr 2015
    170
    Re: Update DOS application for sending NC files
    Try WinDNC, you can download it free from Fagor Automation and other places, it is designed for Fagor controls but should work with others. Dave
    Jan 2016
    4
    Quote Originally Posted by Bdrangdo View Post
    Thank you, I will try that application. From some further searching on the web I see NCnet Lite was recommended elsewhere.
  1. Help sending files via RS232
    By ghansen in forum DNC Problems and Solutions
    Last Post: 12-18-2013, 01:48 PM
  2. Sending files to cnc
    By cbscnc in forum CNC Machining Centers
    Last Post: 07-02-2013, 01:25 PM
  3. Need help sending files
    By Sierra VF2 in forum Haas Mills
    Last Post: 01-30-2013, 06:59 PM
  4. HELP SENDING FILES
    By Sierra VF2 in forum GibbsCAM
    Last Post: 01-30-2013, 01:47 AM
  5. Sending Program Files
    By Astrocncdept in forum HURCO
    Last Post: 05-09-2009, 01:21 PM
