586,069 active members*
3,414 visitors online*
    Biesse Rover 23 Mach 3 conversion
    Hello
    I am about to convert my Rover 23 with Mach3, does anyone have knowlegde of what card to use? And what more stuff I need to buy?
    To begin with, I just want XYZ, motor and toolchanger to work but later on also all other stuff.
    May 2015
    686
    Re: Biesse Rover 23 Mach 3 conversion
    There has been a couple of these machines converted to LinuxCNC and there are build threads on the Linuxcnc forum. There is a much greater range off reasonably priced controller options with LinuxCNC. Pretty sure from what was said they are 0-10 volt analog servos so a Mesa 7i77 will take care of the motion side. Depending on if you want to connect via Ethernet or via PCI/PCIe will determine if you use a 7i92 (ethernet), 5i25 (PCI)or 6i25 (PCIe) to connect it to the PC.
    Rod Webster
    www.vehiclemods.net.au
    Here are some movies from the Biesse with new servos and mach3
    https://www.dropbox.com/s/v8flhnwk02...09.50.mov?dl=0
    https://www.dropbox.com/s/7joa9g4qqq...02.09.mov?dl=0
    Since the servos has been replaced, if anyone is interested of the old servos, feel free to contact me.
    SGDB-20VN
    SGDB-02VN
    SGDB-15VN
    SGDB-10VN
    SGMP-15V316CT
    SGMG-09V
    SGMG-20V
    SGMP-02V3YG11
  1. biesse rover - mach 3 conversion
    By gavztheouch in forum Biesse
    Last Post: 06-24-2020, 10:46 AM
  2. Replies: 13
    Last Post: 10-21-2017, 06:02 PM
  3. Biesse Rover 24
    By lostinbiesse24 in forum Biesse
    Last Post: 12-06-2012, 07:17 AM
  4. Biesse rover 342
    By jimbbk in forum Biesse
    Last Post: 02-26-2011, 09:22 AM
  5. Biesse model Rover A.3 file conversion to DXF
    By Gabriele in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-16-2010, 04:52 PM
