586,071 active members*
4,113 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 4th Axis Inhibit wiring
Results 1 to 9 of 9
    Oct 2008
    1632
    Does anyone have instructions or a schematic on where to install and how to wire the 4th axis inhibit board?
    This is for an older DC machine and running a DC 4th axis.
    Richard
    Nov 2018
    Here is a link, I think can help you. https://www.wiringo.com/custom-wiring-harness
    Oct 2008
    1632
    Re: 4th Axis Inhibit wiring
    Perfect, that fixed me right up, NOT. All posts are nothing but SPAM!
    Quote Originally Posted by young01 View Post
    Oct 2008
    1632
    I found the wiring schematic. Now, can someone show me where is this board typically mounted when it comes from the factory?
    Quote Originally Posted by rwskinner View Post
    Richard
    Aug 2019
    339
    Have a look at those pix. See if you can find anything remotely close to what you need to see.
    https://www.google.com/search?rlz=1C...w=1280&bih=625
    Full disclosure; this is not spam
    Oct 2008
    1632
    Thanks, that was the first thing I did before posting. No luck.
    Quote Originally Posted by Mecanix View Post
    Sep 2009
    103
    Go to "FADALCNC.COM" click on "Technical docs". In the lower left you'll see the Header for Wiring diagrams. Click on 4th axis servo options. Page 5 shows you the wiring diagram for the inhibit curcuit.
    In the "Technical tips" section, look under R for rotary and there is a pdf that explains the Inhibit curcuit and where it locates in the cabinet.
    Jan 2015
    417
    Oct 2008
    1632
    Got it, thanks. The left side of the cabinet is where all my Renishaw components are mounted. I ended up putting it in the big empty area to the right side of the power supply. I know it seemed like a trivial issue but I kind of like keeping things where they go.
    It is funny that out of all the dozens and dozens of control panel pictures out there, I did not find one that had this inhibit circuit. I take it this was something that was added later as an improvement?
    Richard
  1. z inhibit button
    By dieselguy65 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-15-2017, 10:08 PM
  2. Fanuc OT Axis Inhibit light ON problem.
    By rookies in forum Fanuc
    Last Post: 03-22-2017, 03:54 AM
  3. Axis inhibit
    By stevewortley in forum Cincinnati CNC
    Last Post: 09-13-2016, 03:51 AM
  4. Z-axis Inhibit (dry run?)
    By Mooser in forum Tormach PathPilot™
    Last Post: 03-20-2016, 08:51 PM
