586,067 active members*
4,901 visitors online*
Thread: Post Help
Results 1 to 6 of 6
    201
    Post Help
    I am trying to output code from my post in Mastercam. I am adding broken tool detection into the code so it will the post to output the tool diameter. Does anybody know what outputs the tool dia in a mastercam post. I am usign mastercam 2017.
    Apr 2019
    58
    Re: Post Help
    Tool diametr ou can modify in tool section.
    Youtube you can find how to do rhat
    Išsi?sta naudojantis SM-G960F Tapatalk 4 Lt
    Aug 2015
    108
    Re: Post Help
    You have to be more specific.
    There really isn't anything in the post regarding the tool diameter. The toolpaths and geometry for the toolpaths are all set when you program a toolpath with a specific tool in the software. The post doesn't do much regarding that. All its doing is setting planes, taking the toolpath geometry, g & m codes and structuring the program for the specific machine.
    Aug 2019
    339
    Re: Post Help
    Quote Originally Posted by ERUS View Post
    You have to be more specific..
    He is looking for the mastercam's variable name(s) for the "operation tool & dia" so he can call those from the code to do a routine tool inspection e.g. after tool change.
    Aug 2015
    108
    Re: Post Help
    tldia$
    fmt "TOOL" 4 tnote #Note format
    fmt "D" 4 toffnote #Note format
    fmt "H" 4 tlngnote #Note format #jgp was "L"
    fmt "dia" 1 tldia$ #Note format
    fmt "XY" 1 xy_stock #Note format
    fmt "Z" 1 z_stock #Note format
    # Tool Comment / Manual Entry Section
    ptoolcomment #Comment for tool
    tnote = t$, toffnote = tloffno$, tlngnote = tlngno$
    if tool_info = 1 | tool_info = 3,
    sopen_prn, pstrtool, sdelimiter, *tnote, sdelimiter, *toffnote, sdelimiter, *tlngnote, sdelimiter, *tldia$, sclose_prn, e$
    ptooltable #Tooltable output
    sopen_prn, *t$, sdelimiter, pstrtool, sdelimiter, *tlngno$,
    [if comp_type > 0 & comp_type < 4, sdelimiter, *tloffno$, sdelimiter, *scomp_type, sdelimiter, *tldia$],
    [if xy_stock <> 0 | z_stock <> 0, sdelimiter, *xy_stock, sdelimiter, *z_stock],
    sclose_prn, e$
    xy_stock = 0 #Reset stock to leave values
    z_stock = 0 #Reset stock to leave values
    pstrtool #Comment for tool
    if strtool$ <> sblank,
    strtool$ = ucase(strtool$)
    *strtool$
    Aug 2019
    339
    Re: Post Help
    Top man!
  1. Replies: 1
    Last Post: 04-20-2024, 10:26 AM
  2. Replies: 3
    Last Post: 11-30-2016, 07:28 PM
  3. Special post for presentation! Laser manufacturers/dealers post their contacts here!
    By Litografa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2010, 07:23 PM
