586,537 active members*
2,969 visitors online*
    Aug 2016
    43
    UC100 and Galaad
    Hi all .,
    I need some advice..
    I am building myself a new machine to be able to make larger projects , and i have build myself a workbee 1500*1500mm , put together with longs motor steppers , dm542a drivers and then the DB25 bob that was with that package.
    Now i dont have the lpt port needed on my pc , and was therefor thinking about buying the UC100 LPT to USB converter , but i am now starting to doubt if i can use my Galaad software to setup the machine through the uc100 ????
    If there is anyone that knows if its possible , or just has any inputs to the matter it would be appriciated.
    Best regards,
    Kristjan.
    Re: UC100 and Galaad
    Not familiar with Galaad, but it appears to be CAD/CAM?
    You need to use UCCNC or Mach3 to control the machine with the UC100. (UCCNC is cheaper and much better)
    Galaad should export g-code that can be used with Mach3 or UCCNC.
    EDIT: Reading a little more, it looks like Galaad can also control machines? The website is not clear on how it does this, but it will not be able to control a machine through the UC100.
    But again, you can use Galaad created g-code in UCCNC with the UC100.
    Aug 2016
    43
    Galaad uses a build in controller called KAY to control the machines , i have been using kay as a controller for my Isel machine for about a year now... it can be setup for generic machines also ., what is it about the uc100 that would do that it should not be possible ? and sorry for the ignorance but im a noobie
    The UC100 is not a USB > Parallel converter. It's a pulse generator that accepts communicates with and accepts low level commands from UCCNC or Mach3 via a software plugin.
    Aug 2016
    43
    Ah ok... Yeah now i understand.. and no then it will only work with the uccnc and mach software.
    Thx for the help though..
  1. UC100 and C10 Bob
    By kingofl337 in forum CNC4PC
    Last Post: 06-21-2019, 12:17 PM
  2. Galaad Product Key
    By fayt84 in forum Want To Buy...Need help!
    Last Post: 10-19-2017, 10:39 PM
  3. Isel CPM cnc mill & GALAAD user groups?
    By rikshaw in forum Drilling- and Milling Machines
    Last Post: 06-07-2017, 04:25 PM
  4. UC100
    By naijin in forum Australia, New Zealand Club House
    Last Post: 02-01-2016, 04:04 PM
  5. Davinci stepper with Galaad or Kay? Anybody?
    By Pplug in forum Techno CNC
    Last Post: 09-15-2010, 05:00 PM
