586,103 active members*
3,457 visitors online*
    Aug 2009
    57
    Leveling Pads
    Looking for these cast leveling pads. I tried googling the casting number on the bottom but haven't had any luck. These came with a used Cincinnati Milacron machine I just bought but I don't know if they are from Cincinnati or if they are a generic machine base/pad. Was hoping to get another set of them for another machine I have because they are pretty nice pieces. The casting number is 1273273. The base of the cone is about 3-1/2" and the top is about 2-3/8". The hole in the top is about 3/8" and the larger diameter of the taper for the leveling screw to sit in is about 1".
    Thanks for any heads up or for links to something similar.
    Dec 2013
    5717
    Re: Leveling Pads
    Those exact pads don't seem to be available. A Google search did turn up some similar on EBay
    https://www.ebay.com/itm/4-7-16-Dia-...UAAOSwKOJYJdku
    https://www.ebay.com/itm/4-3-4-Dia-C...-/173017719461
    I guess I would just make some from steel if I really wanted a set exactly as you show.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    57
    Re: Leveling Pads
    Yeah, I didn't have any luck with internet searches either. Thanks for trying though!
  1. pads
    By LeWhite in forum Haas Mills
    Last Post: 07-17-2015, 10:46 AM
  2. Leveling pads - steel or rubber?
    By Aaronh in forum Uncategorised MetalWorking Machines
    Last Post: 08-01-2014, 08:00 PM
  3. Bridgeport Mill Leveling Pads
    By minton in forum Bridgeport / Hardinge Mills
    Last Post: 08-15-2009, 05:47 PM
  4. S30 collet pads
    By dbaron58 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 06-03-2009, 04:09 AM
  5. PCB solder pads
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 05-21-2008, 02:53 AM
