586,674 active members*
3,358 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Can anyone help programing a Fagor PLC 64?
    Jun 2006
    138
    I have a Matsuura MC-500V it was retrofitted with fagor controls and uses a PLC 64 to do the automatic tool changes. I found a hard copy of the ladder logic and I have the software, Just need some tips on how to get started, I am not that familiar with programing PLC's with DOS software.
    24223
    What make is the PLC 64? Do you want to modify the program?
    My experience with Fagor PLC's has been programming in mnemonic format.
    Al.
    Albert E.
    Jun 2006
    138
    Oh yeah, I forgot to say it lost its program when it was powered down for a long period of time, and I don't have a back-up so it needs reprogramed or changed out with a better PLC.
    The PLC-64 is made by fagor.
    24223
    What is the Fagor control that is on the machine?
    If you have the listing then it should be possible to type it in to a PC and download it to the PLC, I believe Fagor supply a Terminal program for doing this, also you may be able to use a modem program, but you have to know the serial protocol the PLC is set to.
    Is the PLC built into the CNC or stand alone?
    Also Fagor support are usually very helpfull.
    Al.
    Albert E.
  1. Programing AUX buttons
    By George C in forum Centroid CNC Control Products
    Last Post: 02-10-2007, 08:33 PM
  2. C-Hook programing
    By Russler in forum Mastercam
    Last Post: 01-14-2007, 03:56 PM
  3. Programing book
    By mikeh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-04-2006, 12:47 AM
  4. CAM programing
    By kenlambert in forum G-Code Programing
    Last Post: 02-03-2006, 07:03 AM
  5. Lathe programing help
    By smitty in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-23-2003, 04:39 PM
