586,094 active members*
4,063 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > CNC Routerparts - example to see on site in southern Sweden/Denmark/Norway?
    Hi!
    I'm planning to invest in a CNC from CNC Routerparts to work on large sheets of plywood (1200mmx2500 or 3000) and they have suggested this forum to be in touch with folk that already has one up & running. Have loads of questions, especially about speed, programming and such. Would very much appreciate info on level of difficulty concerning buying one (import from the US, spare parts, reliability, installation, use, programming, etc.. No IT guru myself but able to handle ArchiCAD/Corel and similar on a pretty advanced level. Want the machine for semi-pro serie production of parts in my design (construction/furniture) and also to create custom products (both of plywood and plasma-cut metal sheets).
    Thanks in advance ;-)
    Kotten
    Mar 2016
    22
    Re: CNC Routerparts - example to see on site in southern Sweden/Denmark/Norway?
    Check out YouTube channel Wintergatan. Especially his early ones where he he imported a CNC RouterParts machine to Sweden.
    Regards,
    Arie.
    Sent from my iPad using Tapatalk
    Feb 2005
    829
    Breezy, Wintergatan has moved to southern France.
    Thanks! I appreaciate it ;-)
    - - - Updated - - -
    Cheers! I have relatives outside Auch so I may have the opportunity to come by even there this winter anyway!
  1. Gryphon Vs CNC Routerparts Kit
    By JesseBusenitz in forum Commercial CNC Wood Routers
    Last Post: 11-04-2019, 06:34 AM
  2. Mach 3 and CNC Routerparts
    By HDTHEATER in forum Avid CNC
    Last Post: 03-16-2015, 09:19 PM
  3. CNC Routerparts CRP4848 - control recommendations.
    By nlancaster in forum DIY CNC Router Table Machines
    Last Post: 03-05-2014, 08:23 PM
  4. CNC RouterParts 2x4 ***warning lots of photos**
    By cambosoup99 in forum CNC Wood Router Project Log
    Last Post: 08-28-2013, 08:53 AM
