586,389 active members*
3,035 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Milling AR15 Bolt Carrier Need Some advice
    Aug 2016
    185
    I am trying to lighten my AR15 bolt. This is just a cheap one so thought I would give it a whirl. I have a Harbor Freight X2 Mill and kinda a novice at this. I bought a carbide endmill and this past weekend tried to cut it...
    That was a joke! The mill touched that Bolt Carrier and acted like it was made of un-cuttable material. The endmill heated up and never got anything cut.
    So here's my questions...
    Yes I have the X2 i wanna be a mill machine but it should be able to cut it yes?
    Is this steel so hard that no use in trying or what is the secret? Type of endmill etc?
    I guess I can use a grinder to get the most material gone then clean up with an endmill but how should I do this?
    Aug 2019
    339
    Re: Milling AR15 Bolt Carrier Need Some advice
    AR15? as in assault weapon engineered with a sole purpose to end life???
    you oki my friend?
  1. binding barrel bolt meets a carriage bolt
    By JEK5019 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-15-2019, 03:36 PM
  2. milling an AR15 lower..
    By opcode1300 in forum Gunsmithing
    Last Post: 10-27-2018, 11:23 AM
  3. Replies: 3
    Last Post: 10-12-2017, 01:23 AM
  4. Milling rectangular holes on a bolt circle
    By 69ss396 in forum Haas Mills
    Last Post: 04-16-2010, 10:54 PM
  5. Need some advice / help on broken off bolt.
    By Ace12GA in forum Mini Lathe
    Last Post: 09-08-2006, 10:44 PM
