586,069 active members*
3,820 visitors online*
Thread: Face Driver
    Sep 2005
    274
    Face Driver
    Anybody using a face driver ? new job new machine, turning big shafts (5" dia 3 ft long 316l 304l) and programs that were ran in the past seem very light .05 doc, .006 feed? this is a samsung sl45 with 50 hp. I think It can do better than that. what do you think. its a madison brand driver, dont have the numbers in front of me, any help would be great. thanks
    Sep 2003
    29
    Re: Face Driver
    That machine should certainly handle DOC's larger than that. How well are your drive pins biting in? How much tailstock force does your machine? What type of insert are you using?
    DB34
    Sep 2005
    274
    Re: Face Driver
    Thank's for the response, well I got it up to .150 on a side and .015 per rev with sfm at 450 in 316L nice chips, the insert is a sandvik pos. rake 432 don't remember the number rite now, new to sandvik, its similar to a kennametal kc 5010, the machine is only about 23 % on spindle load in high gear, the machine will do way more but I was wondering about the face driver, part weight and such, got plenty of tail stock pressure, was running it at 250 psi, I don't know what thrust that works out to, (I dont know tail stock piston size and area) I am going less on the back rough turning (away from the driver). the depth of the face driver pins are not that deep just by looking at them, they are a bit beat up, got new ones on the way. never had one slip. I tell you what, this samsung lathe is a good machine, will hold tenth's all day, dont move on lunch break, very impressed! Better then most mori's Iv'e ran and Haas....forget about it, and it's a box way machine. back to the driver, I did get some info but always like to hear from somebody that's doing it. thank's again
  1. integrated face mill vs tts face mill
    By flyingdragon in forum Tormach Personal CNC Mill
    Last Post: 12-24-2015, 01:27 AM
  2. Replies: 10
    Last Post: 09-04-2010, 05:02 PM
  3. Face driver
    By promehanik in forum MetalWork Discussion
    Last Post: 05-12-2009, 04:18 PM
  4. angular contact bearings face to face??
    By powerfade in forum DIY CNC Router Table Machines
    Last Post: 06-19-2005, 05:01 AM
