586,069 active members*
3,629 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > No voltage from DB25
Results 1 to 7 of 7
    Mar 2011
    11
    I have installed a G540, ESS and mach 3 onto my PC. I have followed the steps here https://warp9td.com/index.php/gettin...epper-and-mach
    and I cannot get my motors to move.
    They hold when powered and estop seems to be working. I can see my x and y axis change in Mach 3 after resetting the estop but the motors just hold and hummm white noise.
    I called Gecko and they had me check the output of pins 3 and 25 on the db25 while jogging the left and right arrows on the keyboard for voltage but I only get .054 volts or nothing, no fluctuations.
    Shouldn't the Ethernet smooth stepper test the same way at the db25 port? Because it dosent. I get no voltage on db25 pins 3 and 25 out of the ESS or LPT port when jogging the left and
    right arrow in Mach 3.
    Also is this motor wired correctly? I haven't put in a resistor "5 amp motor not 3.5amp" but I was told its not necessary to test motor output.
    Mar 2011
    11
    Re: No voltage from DB25
    Mar 2007
    2083
    attachment not visible - Invalid Attachment specified. If you followed a valid link, please notify the administrator
    while I have not used a Ethernet Smooth Stepper
    I would double check the mach 3 smooth stepper plug in is installed
    so Mach 3 can use the ESS insread of a PC parallel printer port
    and the ethernet connection is working
    we need a ESS user to reply
    John
    Mar 2011
    11
    I have the warp 9 plugin installed and it comes up and asks for ESS or printer port. It connects after setting the IP address. I can pull the eathernet cable and I get a
    message from mach 3 that the ess is not connected anymore.
    I also fixed the attachment.
    Mar 2007
    2083
    that's OK
    mach3 is obviously communicating with the ESS
    on the G540 do you have the charge pump switch enabled or disabled ?
    not having the current set resistor on the motor cables 9 pin plug results in the current being set to the maximum 3.5A G540 output
    ( fitting a 3K5 resistor results in the current being 3.5A when stepping and the current reduction being active when when the axis is inactive )
    in mach3 pins and ports
    how have you assigned the " printerport" emulated by the ESS
    John
    as its 23:50 I'll download the Mach 3 and ESS manuals
    and continue in the morning
    Mar 2011
    11
    Thanks and yes I have the charge pump off
    "in mach3 pins and ports
    how have you assigned the " printerport" emulated by the ESS"
    I have not done anything in pins and ports regarding the printer port, just set up the motors and estop in there per the ESS instructions. I will post a link in the am....Late for me to now so will check in the am and thanks again.
    Mar 2007
    2083
    I have not found any image on line showing the mach3 ports and pins config when using a ESS
    I assume this mach 3 engine config will be replaced by the ESS plugin and may not be visible
    PC printer port set up replaced by ESS version
    Attachment 426748
    I expect the ESS port 1 will be equivalent to the the printer port 1 on this page -
    ports and pins motor outputs
    Attachment 426750
    G540 "printerport" pin assignment
    Pin Number function
    1 OUTPUT 2
    2 X-AXIS STEP
    3 X-AXIS DIRECTION
    4 Y-AXIS STEP
    5 Y-AXIS DIRECTION
    6 Z-AXIS STEP
    7 Z-AXIS DIRECTION
    8 A-AXIS STEP
    9 A-AXIS DIRECTION
    10 INPUT 1
    11 INPUT 2
    12 INPUT 3
    13 INPUT 4
    14 VFD PWM (50 Hz)
    15 FAULT (input to PC)
    16 CHARGE PUMP (>10 kHz)
    17 OUTPUT 1
    18 to 25 ground
    John
  1. Low Voltage vs High Voltage Stepper motors?
    By Brian_M in forum Stepper Motors / Drives
    Last Post: 06-21-2017, 07:29 PM
  2. Stuck at relay ext dc voltage missing but dc voltage OK
    By adeegbemode in forum Bridgeport / Hardinge Mills
    Last Post: 10-11-2016, 10:08 PM
  3. Chopper drive max voltage vs max voltage of Nema23
    By K_G_B in forum Stepper Motors / Drives
    Last Post: 07-11-2014, 04:17 AM
  4. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  5. Precix 9100 Controller - VI voltage issue Voltage range only 6.5 to 10Volts
    By wdysf150 in forum Controller & Computer Solutions
    Last Post: 08-15-2013, 08:24 PM
