586,058 active members*
3,687 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Home/Hobby laser engraver Laser power on delay issue when engraving need help
    Jul 2017
    348
    hi\i have a small home hobby laser engraver that orig came with a 2000mw laser module and it worked fine no issues at all
    i decided to upgrade to a 5500mw laser module and i installed it and there is an issue
    the laser module has a 2-3 second power on delay so im not able to do engraving....due to the power on delay
    anyone have this issue with laser modules not powering on instantly as they should?
    during an engraving toolpath there can be many start and stops depending on the image you are working on so every time it does this th laser takes 2-3 seconds to power on....i may have to switch back to orig laser if i cant get this matter re3solved
    thank you
    Jul 2017
    348
    Re: Home/Hobby laser engraver Laser power on delay issue when engraving need help
    i did some further testing testing voltages
    when i hook up the 5.5w laser and run the laser toolpath the fan kicks on immediatley and i get 12v to fan
    however the laser does not power on and i have 0v and after about 3 seconds laser powers on but im only getting 4V and stays at 4v during rest of toolpath ...but once it starts a different toolpath the laser again shows 0v for 3 seconds and then powers on and is at 4v...and it does this with both 5.5w lasers using both driver boards...i was sent replacements for both a while back and both have identical issues.
    very strange...im wondering if this has anyhting to do with TTL? ..i have the switch on the driver board set to TTL not analog.
    if i set the switch to analog the laser does not power on at all during entire toolpath.
    Jul 2017
    348
    for both 5.5w lasers and driver boards to be acting the same seems like it could be a setting or technical issue im not doing.or not compatible with my laser machine/controller....to have both lasers and driver boards acting the same is pretty rare.
    Jul 2017
    348
    update issue fixed..it was user install error due to no instructions coming with the driver board
    in order to make new driver board work properly i had to wire driver board TTL + pin to the Arduino D11 pin
    and wire TTL- pin to Gnd pin on arduino
    now no laser on delay
  1. Small hobby home laser engraver .....engraving issue ....laser turning on late
    By Shelby5041 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-02-2019, 11:08 PM
  2. Replies: 0
    Last Post: 11-02-2017, 06:45 AM
  3. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
  4. Hobby laser engraver MT3050DIII
    By mornlaser2014 in forum News Announcements
    Last Post: 08-13-2014, 11:11 AM
  5. Replies: 0
    Last Post: 07-05-2013, 08:44 AM
