586,106 active members*
2,941 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > System variables for Fanuc Control
    May 2018
    74
    Hello all,We have a job that requires changing new insert in the middle of the cane cycle (Rough cut). Sometimes the operator forgets to change it so I want to write a macro to stop the machine and ask the operator to replace a new insert in the middle of rough cut cane cycle.Is there a system variable to record the current position of X or some thing so that I can signal to stop the machine and popup a msg? I know #3006=1 will popup a msg ....Is there a system variable to record the reset button when it is activated?I have a mori seiki TL-40.Thanks for your help
    Mar 2008
    114
    Re: System variables for Fanuc Control
    Break the roughing into two canned cycles with m00 and comment between? Seems simpler to me
    Sent from my G8343 using Tapatalk
  1. Fanuc 0i System Variables
    By dkhayes117 in forum Fanuc
    Last Post: 04-04-2024, 09:50 PM
  2. System Variables Fanuc 11m
    By Molds0 in forum Fanuc
    Last Post: 03-02-2010, 04:00 PM
  3. need help with system variables list for mazatrol m/t pro control
    By uperez in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-25-2007, 04:21 PM
  4. Hitachi Seiki Seicos MYII control system variables
    By pieface in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2006, 07:45 PM
  5. Need detailed information for system variables on Fanuc0m control?
    By Alf012 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-03-2005, 07:52 PM
