586,060 active members*
4,312 visitors online*
    CL access code
    Hello,
    I have a Fadal 4020 CNC 88
    Model 906-1
    Serial 9205252
    It is a 4020 but the axes only move 20 10 and Z Also moves half the distance.
    I want to access the Machine configuration and the diagnostics mode but the control asks for an access code.
    Does anyone knows?
    jolulank
    Enviado desde mi Redmi 5 Plus mediante Tapatalk
    www.doctornumerico.com
    cnc physicians
    Sep 2009
    103
    Re: CL access code
    Perhaps yor parameters are wrong. Can you type "SETP" at the command line to double check them?
    Re: CL access code
    Quote Originally Posted by Tedger View Post
    In fact the parameters are wrong, but some parameters I can not change without the access code ir password
    cnc physicians
    Jan 2015
    417
    Re: CL access code
    Is there no key in the pendant? Sometimes the Keys are wired tied inside the Main cabinet. you need the key
    Jan 2015
    417
    Re: CL access code
    Or if you can not find the keys ... its easy to bypass just open the Pendant i can't remember if the circuit is closed for lock or open... so either connect the wires or separate them that run to the lock. Done. its a very simple on/off type circuit.
  1. access control code AB series 9 or 7300
    By rlegois in forum Milling
    Last Post: 12-12-2019, 07:15 PM
  2. Access Code for 8055
    By peloflex in forum Fagor Automation
    Last Post: 03-07-2017, 02:03 PM
  3. Could not access port driver. Error code:2
    By i_r_machinist in forum PlasmaCam
    Last Post: 10-15-2016, 01:40 AM
  4. Mastercam X2 Verify access code
    By baloghzoltan in forum Mastercam
    Last Post: 04-14-2008, 06:20 PM
