586,036 active members*
3,766 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Looking for electrical dokumentation bridgeport 412 interact
    Nov 2008
    5
    I bought this machine a month ago as "broken" im almost done with my dynamate 4400 retrofit so i have been loking for a bigger machine.
    The problem is that its stone dead on the drivers. It starts and do what it should do (im pressing CE and the memory reding works) until i press the yellow start button then it says -axis drive fault- no lamps on the Bosch drivers ligt up.
    I have done som measuring but its quite hard following al the wires. the "hard" limit switch works (the e - stop ones) the air pressure switch works. i have oil in the lube system but i havent yet (but im going to) checked the oil level switch.
    I Think i have found every fuse in the machine and al of them are ok.
    Do anyone have something that could help me? i would like to get my hands on anyting showing the electrical system.?
    The machine is well taken care of and has no wear at al (and i mean no wear) on the table. they have been using fixture and the cabinet has al the color left inside no scrathes at al just a dent on the cabinet.
    My plan was to retrofit this machine but i want to run it first listening and get a feeling for the machine..
    It is equiped with a 10 000 rpm spindle
    My list of what i in the future want the machine to do is.
    Run closed loop.
    Ridgid tapping .
    have 2 more axis to lift on to the table.
    Easy loding of program.(dont want dropfeed or rs 232
    Retrofit
    Probably something else than the Ethernet smootstepper i run with mach 4 on my dyna. mach 4 is quite ok but with the ess i Think its a litle to much buggs in the system. Here i love to have your toughts of diffrent systems..
    The projekt dont have a tight time scedule thoug i have my dynamate but im eager to get it running..
    Nov 2008
    5
    Re: Looking for electrical dokumentation bridgeport 412 interact
    After reading quite lots of threads here i found a service bulletin poster by machinetech.
    It stated that on the psu 1 and 2 the 24 volt 0 should be connected to earth.
    The previus owner had change one psu. (The one for relay power) and probably not knowing this.
    I dont know why it broked. But now the machine dont get the axis drive fault.
    Here i hoped the story would end but when i power up and al relay get power the 24 volt that should run trough the relay drops to 0
    Back on the horse. I now got 2 sheets of what i Think is the electrics for my machine and i Will try to backtrack.
    Everyones thoughts is apriciated.
  1. Replies: 6
    Last Post: 12-12-2022, 06:18 PM
  2. Bridgeport Interact 1 MK2 Control Heidenhain TNC 2500 electrical diagram
    By guigut25 in forum Bridgeport / Hardinge Mills
    Last Post: 11-21-2018, 08:09 PM
  3. Bridgeport Interact 1 Mark 2 Electrical drawings
    By Andy and Jamie in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2015, 10:06 AM
  4. Replies: 0
    Last Post: 09-29-2011, 11:34 AM
  5. Interact 4 SII, electrical problems.
    By Oviksnc in forum Bridgeport / Hardinge Mills
    Last Post: 10-23-2007, 08:48 AM
