586,072 active members*
4,575 visitors online*
    May 2010
    122
    Using Ball Nose EM
    Hi, I'm looking for information about using Ball Nose End Mills for wood and there's really not a lot of info out there about feeds and speeds and depths of cuts. Or perhaps I'm looking in the wrong areas. Does anyone have any ideas where I should be looking?
    Re: Using Ball Nose EM
    Perhaps you should be looking for ball nose router bits rather than end mills? Cutters for The Brown Stuff are quite different from metal cutters.
    Apr 2004
    5737
    I normally use 2-flute uncoated ball endmills for wood; they basically work fine. The main difference between them and router bits is that they have spiral flutes while the router bits are either straight or slightly slanted. The main thing you need to be careful of is to tighten them firmly; the spirals mean they tend to grab and pull themselves into the work. So if they aren't in there tight enough, they keep going deeper and deeper...
    Andrew Werby
    Website
  1. EM recommendations gr2 ti ball nose?
    By Advil in forum Tormach Personal CNC Mill
    Last Post: 08-21-2016, 11:38 PM
  2. Ball nose Bits
    By zmiller627 in forum CNC Tooling
    Last Post: 09-03-2013, 06:14 PM
  3. ball nose end mills
    By poster in forum MetalWork Discussion
    Last Post: 11-29-2012, 03:20 AM
  4. Bull nose or Ball nose
    By jcnewbie in forum Mastercam
    Last Post: 02-22-2010, 12:35 AM
  5. What type of ball nose to use?
    By gorby in forum CNC Tooling
    Last Post: 12-10-2009, 10:34 PM
