586,055 active members*
4,176 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > How to Wire EMI Filter for 220v VFD?
    Dec 2005
    258
    I have a CW4L2-20A-S EMI Filter.
    Can I just attach L1 to one pole and L2 to the other?
    Where is it best to ground the EMI? (to the VFD Ground terminal or machine frame?)
    TIA
    Eric
    Dec 2013
    5717
    Re: How to Wire EMI Filter for 220v VFD?
    Yes, on the line side, L1 to one side and L2 to the other. Load side, the same.
    All grounds should be connected to the panel at a single point to help prevent ground loops.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2005
    258
    Thanks Jim!
    15362
    Quote Originally Posted by dbtoutfit View Post
    TIA
    Eric
    20A may be on the light side, depends on what size your spindle is
    It would depend how you have your control cabinet wired, the supply to your VFD Drive would normally include a Ground wire so the Ground would connect to the filter along with the L1 and L2 and then connect to the VFD Drive
    Mactec54
    Sep 2005
    1740
    All equipment grounds should be tied together. Power line coming in ground the green or green/yellow to frame, that tie point to the VFD ground and EMI ground.
  1. Cnc machine power wire connecting 220v and 380v
    By allencncrouter in forum Videos
    Last Post: 12-19-2018, 02:31 AM
  2. connecting wire and plug to 220v 3phase vacuum pump Please help!
    By zlswain in forum CNC Machine Related Electronics
    Last Post: 11-05-2013, 08:58 PM
  3. 3 wire 220v, no neutral, can i use 110v?
    By Ksoggs in forum Phase Converters
    Last Post: 12-31-2010, 04:55 AM
  4. wire edm questions, filter settings etc.
    By f32cpe in forum EDM Discussion General Topics
    Last Post: 11-05-2009, 01:00 PM
