586,065 active members*
4,842 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > MX3660 with SainSmart Relay
Page 2 of 3 123
Results 21 to 40 of 46
  1. #21
    Re: MX3660 with SainSmart Relay
    I totally misinterpreted the drawing. I really need to take a class on fundamentals of this stuff.
    I recently installed a C10 BOB as I needed additional inputs for encoder and some proximity sensors. Perhaps using the outputs on that would be more productive than fighting the MX3660. Or perhaps I just should buy the other solenoids?
    I may try wiring as per Maxspongebob’s drawing earlier in the thread. If I could at least get a consistent state on the relay that would be nice. Eventually I will be adding a few pneumatic actuators as well. Getting a drawbar or tool changer stuck in flux would probably be a bad time.
  2. #22
    Here’s a video.
    Note how the LED’s lit dimly despite being in an off state on the controller, then when the pin is activated they turn on fully. Also, sorry for the shaky video, I was recording and trying to touch my touchscreen on the controller.
    https://m.youtube.com/watch?v=FSOAfS...ature=youtu.be
  3. #23
    Mar 2007
    2083
    I have had a look at the video and see the LEDs are dimm when they should be off
    Attachment 427110
    whats the voltage between the SSR board input and common ground when it should be off ?
    it could be either the MX3660 output is leaky
    or possibly a earth loop is causing currents to flow along the SSR ground wire
    and the resulting volt drop is just enough to switch on the LEDs to just start to light
    do the solid state relays switch on ?
    looking for information for the SSR board I found this -
    Input control signal voltage:
    0V - 0.5V Low stage (SSR is OFF),
    0.5V - 2.5V (unknown state).
    2.5V - 20V High state (SSR is ON).
    John
  4. #24
    Mar 2007
    2083
    if you have connected the MX3660 output between the +5V supply and the SSR input like this
    Attachment 427118
    try adding a 1K5 resistor between the relay boards ground and input
    then measure the voltage across the resistor both when the relay is on and when its off
    the voltage across the added 1K5 resistor will indicate the resistance of resistor shown in the MX3660 manual
    if it is 1K as shown in the manual
    when switched on
    the voltage across the added 1K5 resistor will be about 3V ( depending on the loss acros the opto-isolators transistor )
    John
    PS
    without adding the 1K5 resistor between the SSR board input and GND
    the transistor relay driver could sensitive enough to be picking up stray signals that cause the dim light from the LED indicator
  5. #25
    The SSR switches on/off, though sometimes gets caught in the unknown state, meaning the LED light in this video sort of flickers unpleasantly. I tried to catch it in the unknown state, of course it doesn't do it when the camera is on.
    In the video I'm toggling Flood in mach3.
    https://youtu.be/sjDd0g25Hrc
    From the first video, note that output 3- on the MX3660 is connected to input 2 on the relay board (output 3+ is not connect to 5v+, only Output 3- is connected to input 2, this is visible at the end of the first video). The input 2 LED is lighting on the relay board despite the Output 3 pins being turned off in Mach3.
    I haven't had time yet this evening to try the resistor between the ground and the input. My wife is ill, but once i get my 3 year old to bed I'll try to get out there.
    I doubt a ground loop is an issue, I don't have any steppers or accessories connected as I am bench testing, also, my system was dead reliable before. I've added this SSR board, and the additional BOB (nothing is connected to it). But changes being changes, I suppose it's possible.
  6. #26
    Wrong post.
  7. #27
    I get 0V (off) and 5V (on) across the 1k5 resistor. This solves the dimly lit LED issue when off.
    The multiple output issue is persistent.
  8. #28
    Mar 2007
    2083
    Good a small step forward - the 1K resistor shown in the manual must be a link or a low resistance
    Most importantly you have to look after your self so your able look after your family
    next questions
    how have you configured the C10 jumpers ?
    how have you connected the C10 BOB to the MX3660 ?
    there must be a conflict between the C10 and MX3660
    the C10 BOB is unusual in using pin 18 to detect the printer cable is connected
    PS
    ignore the second question I was thinking of the MX4660's second port
    you can still try disconnecting the C10 to see if every thing works when you go back to the original set up
    PPS
    are you using 2 PC parallel printer ports , a motion controller such as warp 9 's Ethernet Smooth Stepper that emulaters 3 printerports or a uc300eth ?
    John
  9. #29
    The C10 is connected to the UC300eth-5lpt.
    The behavior of the MX3660 outputs are consistent with the C10 removed or plugged in.
    I have not even attempted to configure the C10 jumpers, I've been preoccupied with these MX3660 outputs. I'd like to be able to control a few items before I start worrying about the additional inputs that I needed the C10 for.
  10. #30
    Mar 2007
    2083
    I don't have an answer to all of the problems but
    I have had a closer look at the SSR board and the G3MB Solid State Relay used on the board
    and noticed there is not a "snubber " fitted across the SSR
    a simple RC snubber is just a resistor connected in series with a capacitor
    that is connected across the SSR's triac
    Attachment 427182
    others have a MOV added like this
    ssr snubber network with a 220R resistor , 0.1uF capacitor and a MOV (metal-oxide varistor )
    to clamp excessive transient voltages MOVs go form high resistance to low resistance
Name:	ssr snubber network 220R 0.1uF MOV.jpg
    the SSR may not work correctly with some LED lights depending on the ballast used
    or inductive loads
    John
    PS
    this youtube video shows whats inside an ebay 25A Solid State Relay
    that has snubber built in
    https://www.youtube.com/watch?v=DxEhxjvifyY
    the circuit diagram is at 4:37
    PPS
    another snubber from amazon (very like the one from ebay found earlier )
    Attachment 427200
    https://www.amazon.co.uk/gp/product/...26M8PYNT1YRNT7
  11. #31
    I think the hand writing is on the wall here. I need to buy the Fotek units. Continuing to mess with this relay board simply doesn't make any sense.
    I certainly appreciate everybody's contribution here. It's been a real learning experience.
    Once I get the new units and some time to tinker I'll update this thread.
  12. #32
    I got the Fotek units connected up. I ended up installing four of them, all running on 5v, all connected to the four outputs on the MX3660.
    I can switch them all on and off, but they all have a bit of voltage when off. My LED light flickers a bit when the relay is off, my box fan runs very slowly when the relay is off, both items function as intended when the relay is on. I'm sure I need a a resister from something to something else. My brain isn't functioning too well. My wife has been in the hospital since Monday and I've been juggling work and our three year old and everything else. The half hour in the shop sure felt nice though. I might even manage a trip through the shower tonight.
  13. #33
    Mar 2017
    411
    Shower is good. I'm sure your wife will appreciate it.
    The thing about some solid state relays is that they never turn off completely. They leak a bit, especially the cheap one's from China. You could increase the load current and thus reduce the off state voltage at the output.
  14. #34
    My wife hasn't showered since like Sunday, she's been too sick to get out of bed for the most part. I don't think she noticed my lack of hygiene. She's improving though, she could come home as early as this evening.
    The LED light I used to test with is basically on when the relay is off, though it flickers. It's about exactly the same as it was with the relay board before we added the 1.5k resister.
    When you say increase load current do you mean just attach something larger to the load on the relay? With pneumatic solenoids and my coolant pump I'm not sure that's an option, not unless I add a incandescent light bulb in there or something.
  15. #35
    Came across this video, same guy that was posted earlier with the tear down on the Fotek unit.
    https://www.youtube.com/watch?time_c...&v=tzWz_guJHvY
    So yeah, I'll have to test with my pneumatic solenoids to see how they behave. I can plug my coolant pump in and see what it does while I'm at it.
    Given the LED's are such low draw I can see how the leakage powers them, the box fan was a bit of surprise.
  16. #36
    Mar 2007
    2083
    Hope your wife will get better soon
    Don't forget to look after your self , I know how hospital visits can take it out of you
    The Fotek SSR in post 30 has a snubber made from a 10nF capacitor and a 47 ohm resistor in series
    which I expect has solved some of the problems but passes enough current to cause the fans to run slowly and LED light flicker
    depending on the current via the SSR's internal snubber and the threshold voltage the LED's light and the fan starts to turn
    you may be able to fix the problem by adding a resistor as a load
    ( you have to find a resistance low enough to reduce the voltage across the load without dissipating too much power as heat )
    or
    connecting either a 47nF capacitor or another 470nF +100 ohm snubber across the fan or lamp supply terminals
    example snubber
    https://uk.rs-online.com/web/p/rc-ne...itors/2067869/
    to prove a snubber can work
    connect a spare SSR across the lamp
    by connecting terminals 1 & 2 across the lamp / fan
    you effectively connect the spare SSR's snubber across the load
    John
    PS
Name:	Fotek SSR-25 taken from big Clives video.jpg
    Attached Thumbnails Attached Thumbnails Fotek SSR-25 taken from big Clives video.jpg
  17. #37
    Thanks!
    The main thing is that I have four distinct and switchable relays now, which is a huge improvement. I'm close to being functional again should I get the leakage worked out.
    Any guess on what quantity of resistance I would need to control the leakage should I attempt that?
    I can test with the SSR as a shunt this evening as well.
  18. #38
    Mar 2007
    2083
    whats you mains supply voltage ?
    120 V AC as in NA
    or
    230V AC as in Europe ( in my part of the UK my supply is over 240V AC)
    with a 240V supply you could try 68K ( 68000 ohms) 1 W
    John
  19. #39
    I’m in the US, so 110/120 AC.
    Edit: fat fingers, lazy proofing
  20. #40
    Mar 2007
    2083
    for a 120 V AC supply you can use a 15 K (15000 ohm ) 1W resistor to test
    for long term use use a 2W resistor
    120/15000 = 8 mA
    120V x 8 mA = 0.96 W
    for 140V supply use a 22 K resistor
    140 / 22000 = 0.006 mA
    140V x 0.006 mA = 0.89 W
    use a 2W resistor
    John
Page 2 of 3 123
  1. Basic Questions about SainSmart Relay Module
    By atomarc in forum CNC Machine Related Electronics
    Last Post: 08-13-2017, 10:52 PM
  2. How to hook up SSR to sainsmart 5axis?
    By gbrlbll in forum CNC Machine Related Electronics
    Last Post: 06-22-2017, 07:07 PM
  3. Sainsmart CNC Motion Controller
    By Nissan20det in forum Want To Buy...Need help!
    Last Post: 01-18-2016, 12:33 AM
  4. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  5. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
