586,404 active members*
2,627 visitors online*
    Jan 2011
    129
    Laser cutting Issue
    I have been running my 180w CO2 laser using Mach3 with good success.
    I have been using the M 10/P1 and M 11/P1 commands to turn the laser power on and off.
    Recently the laser has been intermittently shutting off and then back on. Within a given file it is shutting off and coming back on at exactly the same places each time I run it and speed does not have any effect on where it shuts off and comes back on.
    The first photo shows what the cut should look like and the second photo shows what I am currently getting.
    It seems to cut circles just fine.
    I have manually turn the laser on while running the parallel lines program and it cuts just fine.
    Anybody have any ideas as to what is causing this?
    Chuck
    Nov 2012
    1267
    Re: Laser cutting Issue
    It sounds like the program itself is turning the laser on and off. Have you checked the G-code for some unexpected M10's/M11's?
    Jan 2007
    229
    Can you run it with RDworks - is it a Ruida controller?
    Jan 2011
    129
    Quote Originally Posted by CitizenOfDreams View Post
    Yes ,I have checked the G code for an expected M10/M 11
    The strange part of this is that it ran fine a while back. And it’s doing the intermittent cutting on other files that have run fine before.
    Jan 2011
    129
    Quote Originally Posted by Stewey View Post
    I don’t have access to these, but I have run one of the files on a different MACH3 machine and it worked fine.
  1. Home/Hobby laser engraver Laser power on delay issue when engraving need help
    By Shelby5041 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-10-2020, 04:01 PM
  2. Small hobby home laser engraver .....engraving issue ....laser turning on late
    Last Post: 09-02-2019, 11:08 PM
  3. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  4. Weird laser cutting issue (not cutting properly)
    By phylo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-06-2013, 06:29 PM
  5. cutting acrylic issue on new amada laser
    By mcangelo4 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-07-2010, 07:04 PM
