586,106 active members*
3,303 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS CM1 lacking performance acceleration-wise;
    Mar 2006
    52
    Small question. Our Haas CM1 has slow acceleration on the x/y/z axis. (eye balling it at around 1000 mm/s2 at most). It's slow as molasses in January for a servo driven machine this size.
    Our bigger Super Mini Mill runs circles around the CM1 in terms of acceleration. (but lacks spindle speed) (10krpm)
    Our main goal for buying this machine was to be able to have quicker machine-times due to the high speed spindle (machining mainly aluminum with smaller mills) It's the 50krpm version.
    It seems that some parameters are not set correctly (and in those lines I expect the acceleration also is set to a factory default or so) the spindle power is 3.7Kw, but the main screen shows 27.3Kw spindle power, and with the warm-up procedure it shows 28% spindle load (7.6Kw) (which on 3.7kw equals to about 1kw, which seems fair for a belt driven spindle at 50krpm with a ~1:4 driver ratio).
    above mentioned issues seem to be parameter related, does anybody knows what parameters take care of the acceleration and/or the projected spindle power?
    Mar 2006
    52
    Re: HAAS CM1 lacking performance acceleration-wise;
    No love for the CM1 here? :cheers:
    Mar 2006
    52
    Anybody here knows what parameters need to be set for the acceleration of a Haas?
    Aug 2009
    230
    I'm sorry I don't have an answer for you, but... can your HFO help? Or contact Haas directly?
  1. Fadal Performance against Haas
    By NorthCoPro in forum Want To Buy...Need help!
    Last Post: 04-11-2016, 12:37 PM
  2. Sheetcam gcode generation lacking
    By jerrysim in forum SheetCam
    Last Post: 06-02-2014, 09:56 AM
  3. Replies: 8
    Last Post: 09-24-2010, 11:39 PM
  4. Lacking some understanding
    By vline5 in forum DIY CNC Router Table Machines
    Last Post: 05-11-2009, 12:58 AM
  5. comparable lathe size wise and price wise to a tormach mill
    By ataxy in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2008, 03:55 AM
