586,106 active members*
3,157 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Machine does not cycle start in any screen other than the main program screen
    Sep 2019
    How do I turn this parameter off? And what is the name of this parameter? Its an OSP-P200LA control on a lathe. We robotic load and unload on this lathe and if its on the offset screen, it will not automatically cycle start.
    Jun 2015
    4154
    Re: Machine does not cycle start in any screen other than the main program screen
    hi, i also learned this trick here, on the forum, from mr wizard : bit 6.0 = 1 , cycle start enabled in other than operation mode / kindly
  1. Replies: 1
    Last Post: 05-20-2020, 01:56 PM
  2. Replies: 1
    Last Post: 02-05-2018, 07:46 PM
  3. z axis setting on the main screen of mach3
    By woodman08 in forum Mach Mill
    Last Post: 02-03-2013, 04:16 PM
  4. Replies: 15
    Last Post: 07-12-2011, 06:31 PM
  5. Mach3 main screen in Spanish?
    By dmauch in forum Mach Wizards, Macros, & Addons
    Last Post: 04-09-2011, 03:26 PM
