587,003 active members*
2,902 visitors online*
    Sep 2019
    54
    Stepper gearboxes ??
    Hi I have a large esab plasma table with old servo motor and gearboxes
    If I was to convert to steppers,
    Will steppers perform better driven through gearboxes or direct drive
    Dec 2013
    5714
    Re: Stepper gearboxes ??
    Steppers are generally best used at low speed. Normally a 2:1 reduction is OK. There is a lot more that goes into the calculation. What torque and speed is required? To use a stepper motor I would multiply the servo torque by 3 to get a starting point for the stepper required torque. But keep in mind that stepper torque drops off dramatically with increasing RPM.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2019
    54
    Ok
    I will calculate the weight of the gantry tomorrow
    And see what gear ratio the servo gearboxes on the table are
    May 2015
    686
    Steppers definitely need reduction gearing for plasma. Try and get somewhere around 1" of movement per motor revolution. Mine does about 30mm which is still ok and even down to 15mm is good too.
    If the servos are still OK, an alternative might be to retrofit with Linuxcnc and a Mesa 7i92 ethernet board and a Mesa 7i77 6 axis servo/encoder daughter card. Add to that a Mesa THCAD board for torch voltage sensing.
    Regardless of if you use steppers or servos, the Linuxcnc plasmac configuration is now without doubt the best plasma controller available on the market place for under $10k because all the THC control is so tightly integrated with the Linuxcnc motion controller and Linuxcnc's PID controllers. Having arc voltage and full access to motion control parameters lets Plasmac do things other external THC's can't even dream of. Full documentation of Plasmac is here PlasmaC User Guide
    Rod Webster
    www.vehiclemods.net.au
    Sep 2019
    54
    Ok thankyou for the input
    Regards
    Quote Originally Posted by rodw View Post
  1. Servos and gearboxes and cnc tables
    By PlasmaGuy in forum Servo Motors / Drives
    Last Post: 12-10-2009, 11:43 PM
  2. Anyone know of a source for gearboxes fo the C2?
    By Claven2 in forum Mini Lathe
    Last Post: 04-15-2008, 02:34 PM
  3. Planetary Gearboxes
    By elogicca in forum Linear and Rotary Motion
    Last Post: 01-23-2007, 07:22 PM
  4. Gearboxes for Steppers
    By vacpress in forum Uncategorised MetalWorking Machines
    Last Post: 07-17-2004, 05:48 AM
