586,060 active members*
4,514 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Cheetah II DC Drive And AcornCNC controller
Results 1 to 7 of 7
    Retrofitting a D&M lathe with a AcornCNC motion controller and am a little weary of how to hook up the DC drive to the motion. However I could just be making a mountain out of a mole hill in my head. Here's what I know:
    *The motion controller supplies a 0-10 vdc signal to the spindle drive
    *The DC drive uses a 10 volt reference signal and an external 10K POT to control spindle speed
    Is it as simple as connecting the motion controllers 10 volt signal to terminals 2&3? (see the attached photos)
    Any insight into this would be greatly appreciated!
    Joey
    Dec 2013
    5717
    Re: Cheetah II DC Drive And AcornCNC controller
    Quote Originally Posted by Joey2point0 View Post
    That's the way I read it. Looks like pin 2 is the common or signal ground.
    Jim Dawson
    Sandy, Oregon, USA
    Adding the DC Drive manual, if additional information is needed.
    Attached Thumbnails Attached Thumbnails SKMBT_C28417021009160 (1).pdf
    Dec 2013
    5717
    According to the manual schematic pins 2 and 3 form a standard 0-10V comparator input circuit. Pin 2 is common, Pin 3 is the 0-10V command signal.
    Jim Dawson
    Sandy, Oregon, USA
    After a little more research I have good reason to believe that it is not possible and will fry my Acorn. The DC Drive is not isolated from the AC supply.
    From a quick search/read KBSI-240D Stand-Alone Signal Isolator should solve my problems but I need to do some deeper digger to be sure.
    If anyone with experience can shine some more light on this it would be greatly appreciated, otherwise I am going to move to Acorns Forum since it seems more fitting. Ill report back when I have a surefire solution
    Dec 2013
    5717
    Using the KBSI-240D can't hurt, another layer of isolation is a good thing and will give you piece of mind. If you look at the schematic, the signal lines are isolated from the AC input power by transformer T1 in the drive. 0V does not seem to be connected to earth ground at any point.
    Jim Dawson
    Sandy, Oregon, USA
    I suppose I could do a simple conductivity test to determine this, will give it a go when I get home today.
  1. Encoder signal to servo drive & controller; split or through drive?
    By strantor in forum Servo Motors / Drives
    Last Post: 08-21-2017, 04:22 PM
  2. 4th drive vs controller in code
    By JasonR in forum Haas Mills
    Last Post: 03-02-2011, 07:56 PM
  3. 5 or 6 axis drive box/controller kit?
    By neeboy in forum DIY CNC Router Table Machines
    Last Post: 11-26-2008, 01:40 PM
  4. Linistepper Drive Controller
    By drhamel69 in forum Stepper Motors / Drives
    Last Post: 10-28-2008, 08:47 AM
