586,068 active members*
3,615 visitors online*
    Jun 2019
    X and Y axis not 90 degrees
    I'm many hours into a confusing problem. On my 100W china laser, the X-axis does not cut at a 90 degree to the Y-axis. My gantry is true and square. When I move the head on the Y-axis front to back it stays straight (measuring from the gantry or wall to the laser head). When I move my X left to right, it measures a half-inch different for the left to right. In other words, from the front gantry rail to the X beam, it can be 5 inches from rail to beam, and on the other side, it will be 5.5 inches. I don't see any adjustments? When I tied to shim the rail end where it attaches to the mirror and guide assembly, it binds in the Y rails. It does a great job unless I need a square cut or a perfect circle, not other things you can't notice it's off.
    The two pictures show what I was explaining, these are two left and right measurements from the true and straight gantry, to the x-axis beam.
    The 3rd pic shows an L square up against the X axis beam showing how out of square it is.
    Any help is greatly appreciated.
    Don
    Attached Thumbnails Attached Thumbnails IMG_5105.jpg   IMG_5106.jpg   IMG_2620.jpg
    Jul 2018
    6339
    Re: X and Y axis not 90 degrees
    No photos Don? Peter
    Jun 2019
    photos
    I tried to upload the photos, not sure if they came through, I uploaded them to this reply, hopefully you can see them.
    Don
    Jun 2019
    not sure why photos aren't showing, I see them on my post - when I view the site not logged in, they are not there.
    Technology is not working in my favor this week.....
    I will try to get this figured out.
    Don
    Apr 2005
    304
    Cool Re: X and Y axis not 90 degrees
    How did you check squareness of your gantry?
    Did you made test firing at the 4 extreme corners of gantry travel and measure diagonals?
    In the attached picture you can see the representation of gantry which is out of square, (over exaggerated), with Y "length" correct (~60 units)
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
