586,119 active members*
3,460 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Partner 1D. Lower Z axis. Machine not under power.
    Jan 2010
    78
    I need to lower the z-axis as low as possible to prep for transport. Especially to get it out of my garage. How do I lower the Z axis, with the machine not under power?
    Mar 2017
    63
    Re: Partner 1D. Lower Z axis. Machine not under power.
    Put a jack under it and remove the z motor, then replace the z motor once tou have it lowered.
    Sent from my SM-N960U using Tapatalk
  1. MiniMill 2 Lower Head NO Power
    By houdini in forum Haas Mills
    Last Post: 04-29-2018, 03:51 PM
  2. Possible to run Delta servo driver with lower power motor?
    By skrubol in forum Servo Motors / Drives
    Last Post: 03-05-2018, 12:27 AM
  3. Replies: 3
    Last Post: 05-28-2016, 09:35 PM
  4. C-axis help on the lower turret
    By JBeeker841 in forum Daewoo/Doosan
    Last Post: 04-28-2012, 06:47 AM
  5. power head to raise and lower non cnc
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 01-05-2008, 07:32 AM
