586,655 active members*
3,327 visitors online*
Results 1 to 14 of 14
    Apr 2005
    1194
    Exclamation Lets talk about BRUTE machines....WOW
    Anyone else have or have seen one of these puppies in action? Brutecnc.com has a listing of the models and the outfits that have bought them. these machines look SERIOUS!
    Machine Travel
    X Axis 31.4" 39.3" 47.2"
    Y Axis 23.6" 23.6" 27.0"
    Z Axis 23.6" 23.6" 23.6"
    Spindle nose to table 4-27.6" 4-27.6" 4-27.6"
    Spindle center to column 23.6" 23.6" 23.6"
    Table length x width 39" x 22" 47" x 22" 55" x 22"
    T-Slots .708" x 4.13" .708" x 4.13" .708" x 4.13"
    Machine base width 31" 38.5" 38.5"
    Machine saddle length 55" 63" 78"
    Door opening width 38.3" 38.3" 38.3"
    Crane loading access Std Std Std
    Max weight on table 4,500 lbs 4,500 lbs 4,500 lbs
    Spindle
    Taper size #40 Taper #40 Taper #40 Taper
    Speed range 0-8,000 rpm 0-8,000 rpm 0-8,000 rpm
    Transmission Digital Direct belt drive Digital Direct belt drive Digital Direct belt drive
    Spindle max torque 220 ft lbs 220 ft lbs 220 ft lbs
    Spindle motor 25 hp 25 hp 25 hp
    CNC temperature controlled XY & spindle XY & spindle XY & spindle
    Ball screw diameter 40 mm 40 mm 40 mm
    Ball screw pitch 10 mm 10 mm 10 mm
    Max rapid rate XY&Z axes 1,181 ipm 1,181 ipm 1,181 ipm
    Max cutting rate XY&Z axes 1,181 ipm 1,181 ipm 1,181 ipm
    Accuracy
    Positioning +/- .0001" +/- .0001" +/- .0001"
    Repeatability +/- .00008" +/- .00008" +/- .00008"
    Tool Changer
    Capacity & type 24 Dual-arm 24 Dual-arm 24 Dual-arm
    Max tool diameter 4.25" 4.25" 4.25"
    Max tool weight 22 lbs 22 lbs 22 lbs
    General
    Air required @ 80-100psi 5scfm/16scfm momentary 5scfm/16scfm momentary 5scfm/16scfm momentary
    Power required 220 VAC 220 VAC 220 VAC
    Amps required 80 amps 90 amps 90 amps
    Coolant tank capacity 32 gallon 32 gallon 32 gallon
    Coolant motor 3 hp 3 hp 3 hp
    Hand wheel Remote Remote Remote
    Rigid Tapping 3,000 rpm 3,000 rpm 3,000 rpm
    Machine size 122" x 125" x 100" 122" x 125" x 100" 122" x 144" x 100"
    Machine weight 12,100 lbs 14,520 lbs 16,500 lbs
    HOLY TEMOLE!
    X Axis 86.6" 102.3" 118.1"
    Y Axis 39.3" 39.3" 39.3"
    Z Axis 39.3" 39.3" 39.3"
    Spindle nose to table 6-45" 6-45.3" 6-45.3"
    Spindle center to column 42" 42" 42"
    Table length x width 95" x 39" 110" x 39" 118" x 39"
    T-Slots .866" x 5.9" .866" x 5.9" .866" x 5.9"
    Machine base width 138" 138" 138"
    Machine saddle length 169" 193" 193"
    Door opening width 87" 102" 118"
    Max weight on table 12,000 lbs 12,000 lbs 12,000 lbs
    Spindle
    Taper size #50 Taper #50 Taper #50 Taper
    Spindle max torque 325 ft lbs 325 ft lbs 325 ft lbs
    Spindle motor 30 hp/40 hp 30 hp/40 hp 30 hp/40 hp
    Axis motor max torque 109 ft lbs 109 ft lbs 109 ft lbs
    Ball screw diameter 63 mm 63 mm 63 mm
    Max rapid rate XY&Z axes 472 ipm 472 ipm 472 ipm
    Max cutting rate XY&Z axes 472 ipm 472 ipm 472 ipm
    Accuracy
    Positioning +/- .0002" +/- .0002" +/- .0002"
    Repeatability +/- .00015" +/- .00015" +/- .00015"
    Tool Changer
    Max tool diameter 5" 5" 5"
    Max tool weight 26 lbs 26 lbs 26 lbs
    Automatic chip removal Washer/auger/conveyor Washer/auger/conveyor Washer/auger/conveyor
    General
    Air required @ 80-100psi 6scfm/18scfm momentary 6scfm/18scfm momentary 6scfm/18scfm momentary
    Amps required 125 amps 125 amps 125 amps
    Coolant tank capacity 133 gallon 133 gallon 106 gallon
    Coolant motor 7 hp 7 hp 5 hp
    Rigid tapping 3,000 rpm 3,000 rpm 3,000 rpm
    Machine size 197" x 236" x 110" 197" x 267" x 110" 197" x 299" x 110"
    Machine weight 60,910 lbs 67,925 lbs 78,545 lbs
    Damn where did these guys come from???
    Dec 2006
    247
    Probably china???
    Look at their website and their new plant.
    New facility for Arcade Machine Inc. of Asia
    Asia Huh what does that mean???
    What are you a salesman????
    Joe
    Oct 2005
    672
    They don't seem any different than many other machines. The company I worked for (Dynamechtronics) had a 32" x 20" machine that weighed 12,000lbs and a 43" x 22" machine at 16,000lbs. My Dynas weigh 4500lbs and are little #30 taper machines with 14" x 10" travels. Check the specs on Mazak, Matsuura, Republic Lagun, Tree, Mighty, Mori Seiki and others. For some reason, people forget that Haas and Fadal are among the lightest duty machines on the market.
    Dec 2006
    247
    I agree I have no idea how good or bad these machines are but when somebody has a post like that it reminds of the guy who has a tip on a stock email, It just seems a little fishy. could be a great machine and they look nice I just don't like the way it was presented.
    Joe
    Apr 2005
    1194
    Quote Originally Posted by joecnc1234 View Post
    Probably china???
    Joe
    I really want to add an insult here but I will hold back. You should check my other posts before you think I am a salesman but I dont expect everyone here to be savvy. Point is the big three car manufacturers use these machines so they must be robust. I hate it that the castings come from overseas and that was why I never looked twice at Milltronics. Is their any company that does meehanite domestically? I am a shop owner and a machinist not a salesman. Maybe you should look over the specs on the machines with a clear head.(wedge)
    Smile Big CNC Machines
    Carbidecraters
    Don't feel bad I was yelled at when I wanted to spend 5000 dollars for some thing. It seems many readers don't know where stuff comes from now. FORD made in CANADA. CHEVY made in MEXICO. The made in America people should not buy Ford or Chevy! A very popular vehicle (pick up) is made in the USA and named the -TOYOTA ! That is one Heck of a machine that you talk about. I am always faced with the part not fitting on the table. With this machine no one has to worry. Wish I had one of those sitting here for me to machine some thing. So again don't fell bad about what you read. By the way many folks lie too.
    Lee
    The more you know teaches you don't know alot
    Apr 2005
    1194
    Ford/GM/Chevy get chinese parts shipped to South Korea and are presented as South Korean parts. Toyota parts are also coming from China and shipped to the United States for assembly. It is obvious to me that these castings arent being done here and the machines final finish is horrible however their customer list and machine list is VERY impressive.
    Customer Description
    ACUSTAR NEWCASTLE 12 STA SWAGE TRANSFER
    ALLISON DRILL RSM SHUTTLE
    AM MOTOR RTV - 6 CYC
    AM MOTOR DOUBLE TRANS RTV
    AMERICOLD DOUBLE END
    AMERICOLD DOUBLE END GROOVE & FACE
    AO AMITH SINGLE SP GUN DRILL
    ATLAS CRANKSHAFT REBUILD BAKER TRUNNION
    ATLAS CRANKSHAFT REBUILD GREENLEE TRUNNION
    ATLAS CRANKSHAFT BAKER 6 STA TRUNNIOIN
    ATLAS CRANKSHAFT GREENLEE 6 STA TRUNNION
    BOHN ALUM 6 STA TRUNNION
    BOHN ALUM 3 STA DIAL
    CADILLAC PHOTOTRACE RTV
    CASE 1 LOT - 5 - LARGE DRILLHEADS
    CATERPILLER YORK 4 STA DIAL
    CHEV BUFFALO PHOTOTRACE DIAL RTV
    CHEV BUFFALO DOUBLE END SWAGE
    CHEV DIV GMC 2 PUSH ROD COVER RTV
    CHEV ENG 27 STA CENTER COLUMN
    CHEV ENG 7 STA GASKET APPLICATING
    CHEV ENG STAND CIRCLE TRACK GASKET
    CHEV FLINT ENG 2 - 6 STA TRANS
    CHEV FLINT ENG 2 PHOTOTRACE RTV
    CHEV FLINT ENG 7 RTV SPIN
    CHEV FLINT ENG 2 RTV - ROCKER COVER
    CHEV FLINT ENG 10 BASIC RTV
    CHEV FLINT ENG SINGLE AXIS RTV
    CHEV FLINT ENG SEMI AUTO LINE RTV
    CHEV FLINT ENG 3 SINGLE AXIS RTV
    CHEV FLINT ENG RTV
    CHEV FLINT ENG 6 STA TRANS
    CHEV FLINT ENG RTV TRANS
    CHEV FLINT ENG 2 CAM SPIN RTV
    CHEV FLINT ENG TRANSFER MACHINE
    CHEV FLINT ENG 2 SPIN RTV
    CHEV FLINT ENG 2 AXIS GASKET APPLICATING
    CHEV MFG 2 PHOTOTRACE RTV
    CHEV PARMA 2 INLINE TRANSFER
    CHEV TONAWANDA 2 SINGLE STA RTV
    CHEV TONAWONDA 4 - 6 STA TRANS RTV
    CHRYS DET FORGE BEND & QUENCH SWAGE
    CHRYS DET FORGE 2 ERIE PRESS TRANS UNITS
    CHRYS KOKO 12 STA DIAL
    CHRYS KOKO 14 STA DIAL
    CHRYS KOKO 6 STA DIAL
    CHRYS KOKO 6 STA KINGSBURY
    CHRYS KOKO RTV
    CHRYS KOKO 8 STA DIAL
    CHRYS KOKO REBUILD KINSBURY
    CHRYS KOKO REBUILD ARCADE GUN DRILL
    CHRYS KOKO 6 STA DRILL
    CHRYS KOKO 5 STA DIAL
    CHRYS KOKO 4 GUN DRILL MACH
    CHRYS KOKO 10 STA CENTER COLUMN DIAL
    CHRYS KOKO 22 STA PALLET TRANS
    CHRYS KOKO DRILL & REAM
    CHRYS KOKO MACHINING STA 6188
    CHRYS KOKO 6 STA CENTER COLUMN
    CHRYS NEW PROCESS SPECIAL MILL
    CHRYS NEW PROCESS 2 HORIZ DRILL
    CHRYS NEW PROCESS 2 - 5 SP HORIZ DRILL
    CHRYS NEW PROCESS 9 STA TRANS
    CHRYS NEW PROCESS 3 WAY DRILL
    CHRYS NEW PROCESS 11 STA CENTER COLUMN
    CHRYS TRENTON RTV
    CHRYS TRENTON FACE & CHAMFER
    CLIPPER INT DOUBLE END SWAGE
    COPELAND IN LINE TRANS
    COPELAND GROOVE MILL
    COPELAND DRILL DIAL
    COPELAND 2 GUNDRILL TRANS
    COPELAND CRANKSHAFT TURN TRANS
    COPELAND 30 STA CENTER COLUMN
    COPELAND 6 STA GUNDRILL
    CROSS CNC RTV
    CROSS 2 PHOTOTRACE RTV
    DANA MAGNA CAM
    DANA PHOTOTRACE RTV
    DANA SINGLE STA DRILL
    DANA MAGNA CAM
    DANA 4 MAGNA CAM
    DANA REWORK NATCO MACH
    DANA REWORK DANA
    DANA FT. WAYNE DOUBLE END MILL & CENTER
    DANA FT. WAYNE FACE & CENTER
    DANA FT. WAYNE DRILLING
    DANA FT. WAYNE 3 STA TRANSFER
    DANA FT. WAYNE MILL
    DANA FT. WAYNE MILL
    DANA PARISH REWORK 4 STA APPEX
    DANA PARISH 4 STA DIAL
    DANA PARISH 3 WAY BORING
    DANA PARISH 3 WAY MILL & BORE
    DANA PARISH REWORK ASTA
    DANA PARISH DRILLING MACHINE
    DANA SYRACUSE RETOOL APEX
    DANA SYRACUSE FACE & CENTER
    DANA TOLEDO REWORK BAKER DRILL
    DANA TOLEDO REWORK BAKER TAP
    DANA TOLEDO REWORK NATCO MACH
    DANA TOLEDO CONVERT NATCO MACH
    DANA TOLEDO 2 REBUILD SNYDER
    DANA TOLEDO REWORK 4 STA DIAL
    DANA TOLEDO REBUILD SNYDER
    DEBLISS COMPANY 8 STA CENTER COLUMN
    DEEHLER JARVIS 5 STA DIAL
    DEVILBISS 8 STA DIAL
    DEX INDIANA 5 STATION TRANSFER
    DEX INDIANA 3 STATION TRANSFER
    DEX INDIANA 4 STATION ROTARY DRILL
    DEX INDIANA HORIZ DRILL
    DEX INDIANA 3 STATION SHUTTLE MACHINE
    DEX KOKOMO 12 SPINDLE GUN DRILL
    DEX KOKOMO FLEX CROSS HOLE DRILL
    DOEHLER JARVIS TUBE CUTOFF & CHAMFER
    DONOVAN CONSTR. 2 SHELL MARKETING MACH
    DONOVAN CONSTR. 2 SHELL KNURLING MACH
    DOUGLAS AUTOJEC 5 VERTICAL SWAGE
    DSA MAGNA TRACK
    DSA MAGNA CAM
    DSA MAGNA CAM
    DSA PHOTOTRACE
    DURR SWAGE TRANSFER
    FEDERAL MOGUL HORIZ BROACH BRG WALLS
    FEDERAL MOGUL HORIZ BROACH BRG HEIGHT
    FEDERAL MOGUL 3 STA TRUNNION GROOVER
    FEDERAL MOGUL 3 STA TRUNNION FACE & CHAMF
    FEDERAL MOGUL 2 MANAUL HEIGHT BRANCH
    FEL PRO CNC RTV
    FORD BATAVIA 2 STATION TRANSFER
    FORD BATAVIA DRILLING MACHINE
    FORD BATAVIA 2 - 6 STA DIAL
    FORD BATAVIA 2 - 3 STA DIAL
    FORD BATAVIN 3 POS DRILL
    FORD C.E.P #1 10 STATION CENTER COLUMN
    FORD CEP 21 STA TRANS
    FORD CLEVELAND 2- RETOOL KINGSBURY
    FORD CLEVELAND 3 RETOOL KINGSBURY
    FORD CLEVELAND 23 STA CENTER COLUMN
    FORD DBN 4 VERT DRILL PRES
    FORD DEARBORN 6 STA CENTER COLUMN
    FORD DEP 2 RETOOL SNYDER NOTCH MILLS
    FORD DON ENGINE 6 STA DIAL
    FORD ENSITE THO ROLL TRANS
    FORD ESSEX 27 STATION TRANSFER
    FORD ESSEX 12 STATION CENTER COLUMN
    FORD ESSEX 9 STATION CENTER COLUMN
    FORD ESSEX STATION 8 OIL PUMP
    FORD ESSEX CRANKSHAFT TRANSFER
    FORD ESSEX RETOOL ASSY. MACHINE
    FORD ESSEX LEAK TEST
    FORD ESSEX ASSEMBLY
    FORD ESSEX 4 STA DIAL
    FORD ESSEX CENTER COLUMMN DIAL
    FORD ESSEX 10 STA CENTER COLUMN DIAL
    FORD ESSEX 12 STA CENTER COLUMN
    FORD INDY REWORK B&H TRANSFER
    FORD INDY SWAGE TRANSFER
    FORD INDY SUNBURST
    FORD INDY SUNBURST DRILL
    FORD INDY BROACH & MILL TRANS
    FORD INDY DUP 6559
    FORD INDY SUNBURST
    FORD INDY 6 STA SWAGE TRANS
    FORD INDY DOUBLE END SWAGE
    FORD INDY 6 STA TRANS
    FORD INDY SHUTTLE
    FORD INDY TRANSFER MACHINE
    FORD INDY 5 STA SWAGE
    FORD INDY 15 STA TRANS SWAGE
    FORD INDY 14 STA TRANS SWAGE
    FORD INDY 2 BROACHING MACHINE
    FORD LIMA PHOTOTRACE RTV
    FORD LIMA CAM/SPIN RTV
    FORD LIVONIA 3 STATION FLEX DIAL
    FORD LIVONIA 3 STATION TRANSFER
    FORD LIVONIA SUNBURST DRILL
    FORD LIVONIA 4 STA DIAL
    FORD LIVONIA RETOOL TURNER
    FORD LIVONIA BRUSH DEBURR
    FORD LIVONIA BRUSHING PRESS
    FORD LIVONIA IN LINE TRANS
    FORD LIVONIA 8 STA DIAL
    FORD MONROE CONVERTOR MILLING MACH.
    FORD MONROE BAR END TURN TRANSFER
    FORD MONROE REHAB AJAX PRESS
    FORD MONROE 5 STA TRUNNUIN
    FORD SHARONVILLE 3 STATION TRANSFER
    FORD SHARONVILLE 7 STATION DIAL INDEX
    FORD SHARONVILLE 4 STATION DIAL INDEX
    FORD SHARONVILLE AUTO LOAD ELEVATOR
    FORD SHARONVILLE 6 STA DIAL
    FORD SHARONVILLE RETOOL LASALLE TRANS
    FORD SHARONVILLE SUNBURST
    FORD SHARONVILLE SMF TRANS REWORK
    FORD SHEFFIELD 20 STA TRANS
    FORD SHEFFIELD 3 STA DIAL
    FORD SHEFFIELD 20 STA CENTER COLUMN
    FORD STERLING DOUBLE END CHAMFER
    FORD STERLING 6 STA DIAL
    FORD STERLING 5 STA DIAL
    FORD STERLING 2 STA MILL
    FORD STERLING DOUBLE END SWAGE
    FORD STERLING RTV
    FORD STERLING REHAB SWAGE
    FORD STERLING 2 RTV
    FORD STERLING TEMPLATE RTV
    FORD STERLING REBUILD TRUNNION
    FORD VAN DYKE 2 PHOTOTRACE RTV
    FORD VAN DYKE 2 RTV
    FORD WINDSOR 1-2 SP TAPPING HEAD
    FORD YPSI COIL BENDING INDEX
    FORD YPSI 4 STA DIAL - COIL FORM
    GE WATERFORD NY RTV
    GE WATERFORD NY MODIFY RTV HERSHY DOT DISP
    GM CANADA 2 RTV TRANS
    GM CANADA SINGLE AXIS RTV
    GM ST CATHERINE DOUBLE END SWAGE
    GREENLEE 20 STA TRANS
    HYDRAMATIC 9 PHOTOTRACE RTV
    INGERSOLL RAND PHOTOTRACE RTV
    INT HARVESTER DRILLING MACHINE
    INT HARVESTOR 4 POS SHUTTLE
    INT HARVESTOR 6 STA DIAL
    INT HARVESTOR DEEP HOLE DRILLING
    IPE INDUCTION MACHINE
    JI CASE 14 LARGE HEADS & BP
    JI CASE 5 POSITION SHUTTLE
    LANDIS DOUBLE END
    LANDIS DRILLING
    MACK TRUCK 2 POS SHUTTLE
    MACK TRUCK 7 STA DIAL
    MACK TRUCK 8 STA DIAL
    MACK TRUCK RETOOL BUHR DRILL
    MACK TRUCK BREBUILD BAUSCH DRILL
    MACK TRUCK SPECIAL DOUBLE END FACE/TURN
    MACK TRUCK 3 STA DIAL
    MACK TRUCK 6 STA DIAL
    MACK TRUCK 6 STA CENTER COLUMN
    MATSUI PHOTOTRACE RTV
    MERCURY MARINE DRILL / TAP SHUTTLE
    MERCURY MARINE 2 POS GUN DRILL
    MERCURY MARINE SHUTTLE PROP SHAFT
    NEW IDEA 2 - 3 WAY BORING
    NISSON 4 F.I.P.G. MACHINE
    NORDSON 6 GUN MOVERS
    NORDSON 2 GUN MOVERS
    NORDSON 6 OVERHEAD POSITIONERS
    PNEU INC 2 PHOTOTRACE RTV
    PONTIAC 6 CAM RTV
    PONTIAC 8 PIVOT ARM RTV
    PONTIAC 2 STD RTV
    PONTIAC 5 MI-I RTV
    PONTIAC 2 MI-I RTV
    PONTIAC RTV W/3 SETS FIXT
    PONTIAC SPIN RTV
    QUAN EX 5 STA SWAGE TRANS
    REHNBERG INDEX TABLE
    REINHART MAGNA CAM
    RENAULT TEMPCATE RTV
    REXSON PHOTOTRACE DIAL RTV
    ROCKWELL INT RETOOL NATCO (TRANSFER)
    RWC RTV
    SAGINAW ACA 9 STA CENTER COLUMN
    SAGINAW ACA 7 STA SWAGE TRANS
    SAGINAW ALA 38 STA TRANS
    SAGINAW ALA 52 STA TRANS
    SAGINAW ALA 2 - 18 STA TRANS
    SAGINAW ALA 7 STA TRANS
    SAGINAW ALA SWAGE CANCELLED
    SAGINAW ALA 4 STA HORIZ FORM
    SAGINAW ST SWAGE TRANSFER
    SAGINAW STEERING HORIZ DRILL
    SAGINAW STEERING 4 STA INDEX SWAGE
    SAGINAW STEERING 5 STA DIAL
    SAGINAW STEERING 2 FACE & CHAMFER
    SAGINAW STEERING DOUBLE END SWAGE
    SAGINAW STEERING 60 DIAL INDEX
    SAGINAW STEERING 5 STA SWAGE TRANS
    SAGINAW STEERING PALLETIZED TRANSFER
    SAGINAW STEERING RETOOL 8 STA KINSBURY
    SAGINAW STEERING 2 CHAMFERING MACHINE
    SAGINAW STEERING SPEC DOUBLE END SWAGE
    SAGINAW STEERING SPEC SWAGE MACHINE
    STANADYNE 8 STA DIAL
    SYSTOMATION SILICONE APPLICATOR
    TELEDYNE CONTINENTAL TEMPLATE RTV
    THIOKOL 2 KNURLING MACHINES SHEILS
    TRW GROOVE & WIRE BRUSH
    TRW SWAGE MOTOR SHAFT
    TRW SWAGE ARM SHAFT
    TRW 12 STA TRANSFER RACK
    TRW 12 STA TRANSFER SHAFT
    TRW BROACHING MACHINE
    TRW 6 STA DIAL
    TRW LIFT & CARRY SWAGE
    TRW CLEVELAND TWIN O MATIC
    TRW CLEVELAND TWIN O MATIC MILL/DRILL
    TRW ROGERSVILLE RETOOL SWAGE
    VISTEON EFHD CNC TURNKEY (Mori Seiki)
    VISTEON EFHD 4 STATION FLEX DIAL
    VISTEON INDY STAND ALONE
    VISTEON INDY TRANSFER/SWAGE
    VISTEON STERLING 7 STATION DIAL INDEX
    WARNER GEAR 2 TEMPLATE RTV
    WARNER GEAR CAM/SPIN RTV
    WARNER GEAR 2 TWIN TEMPLATE RTV
    WARNER GEAR TEMPLATE RTV
    WESTING HOUSE GUN DRILL CONTROLS
    Oct 2005
    672
    The big three use everything, good or bad so that's not really an endorsement.
    No one does castings of that size domestically. Haas and Fadal are no more "Made in USA" than anything else. The EPA and OSHA have made big castings cost prohibitive. Even the Japanese machines and automobiles have all the big castings done in China.
    I looked at the specs. I pointed out they are nothing special. The Brute machines are no better than machines offered ten years ago from Dynamechtronics, Mighty/Viper, Femco, Tree, Republic Lagun, and others. The Brute does look stouter than the light duty linear guide machines from Haas, Fadal, Bridgeport, Cinncinnati, Hardinge, and Milltronics but that isn't saying much.
    Dec 2006
    242
    User list is irrelevant
    That user list had nothing to do with Vertical Machining. The name of each machine or operation was given, so take a look at it. How would a VMC be used in swaging or in a transfer line?
    The heaviest machines come from South Korea (Daewoo/Doosan), Taiwan and China. That's been true for a long time. I own a Mighty Mustang C-42, which has box ways. With 20" x 42" travel, it's lighter than a Haas at 9,000 lbs vs. apporx. 12,000 lbs and from the cuts I made in a demo video, Haas users told me their machine could not keep up with it. 1018 steel, 2" 45 degree SEKN Face mill, .150"-.200" deep, .015" fpt, 1800 rpm. I saw a Daewoo Mynx 500 (20" x 40") machine with box ways and 16,000 lbs run an Iscar 1.5" three flute APKT type endmill .500" deep slotting in 1018 steel. Try that with a 50 Taper Haas.
    we have a quantum and an enshu as well as a number of jap machines, both 50 taper machines i beleave are korean machines , absolutely trouble free work horses , i highly a doubt hass could keep up to what we put those two machines thru 24/7,especially after talking with guys i know that own them , they a mearly an affordable machine , the chevy's cavellier of machines , and fadal well thats a no good piece that i hope never to touch again ,thats the lada of machines
    and where are they made ?
    bottom line is the japanese can t be beat but there are some good machines out there for the guy that can t always afford them
    Dec 2006
    242
    Enshu is Japanese, not Korean
    Hey man, you're driving a Lexus, not a Hyundai. Enshu is a step above even Mori Seiki in terms of design and durability if that's possible.
    http://www.enshuusa.com/
    Quote Originally Posted by davereagan View Post
    really ?
    i had alway thought is was korean ,they are definitely as reliable as the mori's,
    its an ev650 , theres no stopping the sucker ,and very accurate but some of the inner design is quite flawed in reguards to covers , and chip evacuation , chips get where we really don t want them ,we plan on one or two simple mods to solve this issue but on the other hand i can put a lot of the blame on the operators , if i wasn t on top of them the machines would never get cleaned
    Jun 2004
    26
    Are these really heavy machines?
    Or do you mean for the table size and travel they have quit a bit of iron?
    There, I gave you an answer
    When I worked for United Airlines I was put on a Shibaura horizontal boring mill
    It had a 14" quill that reached out 42"
    The head went up vertical about 2-1/2 stories high
    The rotary table was big enough to put one of these "small" VMC machines on and turn it into chips
    I once calculated that with the smaller 12" shell mill I could remove over
    4 cubic inches of aluminum per second, and it asked for more
    I figure 75-80 tons was the weight of this monster, maybe more
    How's that for heavy?
    By the way, The only way you are going to hold .00008 (80 millionths)
    repeatability over time is to use a machine with linear travel encoder
    feedback, even if it does have liquid chilled ball screws
    And this is also true for the newer linear magnetic drive systems that
    have no ball screws
    Has anyone ever looked at a Hermle?
    The whole bottom of the machine is made from granite
    How's that for a base to build a solid stable machine on?
    Widgits
    May 2010
    so would you say that brute is comparable to mori machines. as in being stable to hog out steel. or more for finishing????? we are lookig at buying a brute. we cut molds. so we are looking for a machine to hog. and finish tools but want to keep the price down???
  1. Lets try this again
    By Gadzooks/Steve in forum Mini Lathe
    Last Post: 01-06-2007, 05:47 AM
  2. Lets talk financing
    By carbidecraters in forum MetalWork Discussion
    Last Post: 04-18-2006, 08:00 AM
