586,036 active members*
3,629 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa SGM series servopacks - is it possible to control them on DIY machines?
    Dec 2005
    59
    Guys i need serious help.
    I have a set of servopacks with matched ac motors. They are Yaskawa SGM series AC servomotors (SGM-08AFFJ12) with DR2 series servopacks (DR2-08AC-NY41).
    Is it worth to think about buying them? My concern is if will i be able to control the motors using soft like Mach3 or linuxcnc or other STEP/DIR based controllers? Second thing is PID parameters tuning - any Yaskawa software avaiable for free without need of 'special kables' directly from NASA?
    I'd love to use them but is it possible for amateur to use them?
    Many thanks!
    Bogi
    Oct 2009
    78
    Re: Yaskawa SGM series servopacks - is it possible to control them on DIY machines?
    I believe that motor is Sigma II and the DR2 drive is from the Sigma I era. Sigma I and Sigma II components are not compatible primarily due to the pulse encoder resolution. If you can't find the drive and motor in the same document then you aren't looking at compatible components.
    Do your home work
    https://www.yaskawa.com/downloads?p_...bSelected=tab1
    Obama's Miracle > One pill will treat all of the old folk's health problems
    Dec 2005
    59
    Hey,
    first i already told ya the drives and motors are matched - they were dismounted from the same machine. Do your home work - NY41 version is a special series made purpousely for one company for their IC pick&place machines. Not compatibile with other yaskawa equipment - this is the reply i got from Yaskawa.
    Oct 2009
    78
    Should be very entertaining to integrate the drives without reference material.
  1. TC Series Yaskawa Motors on Z
    By Marty_Escarcega in forum Bridgeport / Hardinge Mills
    Last Post: 10-24-2021, 02:58 PM
  2. YASKAWA AC SERVO and SERVOPACKS circuit breaker sizing and IP44 cable
    By graupnerhansen in forum CNC Machine Related Electronics
    Last Post: 04-17-2017, 09:56 AM
  3. Problem Dead Yaskawa 626 MT2 B Series
    By bborb in forum Phase Converters
    Last Post: 03-29-2012, 12:46 PM
  4. Problem Dead Yaskawa 626 MT2 B Series
    By bborb in forum DNC Problems and Solutions
    Last Post: 03-22-2012, 09:46 PM
  5. Yaskawa SGDS servopacks & motors.
    By 666 in forum Servo Motors / Drives
    Last Post: 10-25-2010, 06:09 PM
