586,061 active members*
4,414 visitors online*
Results 1 to 9 of 9
    Feb 2008
    26
    dc negative short to ground
    Im retrofiting a votan cnc machine, im trying to use the existent controll panel (box) and all the dc control wiring that includes all of the machine relays,solenoids etc exept for the ac stuff.
    problem is that when i test for continuity between the dc negative rail and earth ground i get a dead short.
    is it normal or does it mean there is some component (rele,solenoid etc.) that has a short to ground.
    Dec 2013
    5717
    Re: dc negative short to ground
    It may or may not be OK.
    If the DC power comes from a transformer that isolates it from the AC supply, it is possible that one leg of the transformer secondary is earthed. This is a common way of doing it.
    If the DC power is directly rectified from the AC line with no transformer isolation then there is a problem.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2008
    26
    there was a isolating PS , but it was a 380v input so i have exchange the original Ps by a chinese 24vx14 amps Ps and installed a isolation transformer to the mains input of the chinese Ps.
    the thing is that without the power supply conection to the 24v rails there still be a short between negative and ground on the wiring, not the power supply.
    Dec 2013
    5717
    It is possible that the DC bus negative rail is grounded at the bus. Look for a green/ yellow wire connected to the DC negative bus
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2008
    26
    Right on it! any reason for that?
    Dec 2013
    5717
    This is very common, especially on European machines. Both grounded or ungrounded works, but I always ground the DC bus negative just to keep everything referenced to earth ground. Seems to help with electrical noise. There are some instances that require isolated DC, but these are not common.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2008
    26
    you are the man. so i´ve this chinese power supply that shares the common with the - output, it is not isolated but i´ve used a isolation transformer on the power supply mains input. i dont think there will be a problem with the negative of the bus connected to the earth or there will be? thanks btw.
    Dec 2013
    5717
    I think it will be OK, I have a Chinese 24V power supply wired that way on one of my machines, has been working fine for the last year or so.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2008
    26
    Thank´s a lot.
  1. Motor positive or negative ground
    By onthemarc in forum CNC Machine Related Electronics
    Last Post: 02-03-2018, 05:43 AM
  2. how short is too short for necks?
    By qotsarock in forum Musical Instrument Design and Construction
    Last Post: 10-26-2010, 04:55 PM
  3. Frame ground vs. Electrical ground.
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2008, 11:21 PM
  4. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
