586,094 active members*
3,942 visitors online*
    Feb 2008
    26
    hydraulic tool changer
    Hi All,
    i´m retrofiting a Wotan machine center, 3 axis mill . the manufacture has gone out of bussines and i´ve got this machine used with no controller . I´ve new servo drives on it.
    the tool clamp /unclamp is done by a hawe hydraulic pump + valves+ a round reservoir that i gues is a intensifier and it is working but i´ve no idea on how it works .i would like to know how it works so i can retrofit the command for it.
    should the pump run continuos? or just to pressurize the system. does it clamp and unclamp by pressurized oil or spring return.
    the pump is one those small compact system has one one solenoid and another one that i can not figure out if it is a solenoid or pressure switch.
    I guess some maho cnc machine use a similar sistem
    Jun 2010
    4256
    Re: hydraulic tool changer
    Manufacturer has gone out of business?
    Then you have an open opportunity to do whatever you want!
    Cheers
    Roger
    Feb 2008
    26
    Yes, i´m doing it :-)
    i´ve figured it out already. its a spring return.
    the pump only runs to pressurize the system, there is a accumulator ( nitrogen) . there is a preassure switch on the pump that turn the pump on when preassure drops. a relay tuns the pump on /off and another relay to turn on a solenoid to release the tools.
    I´m using Hiwin servo drives on heindhain servos and renco encoders + toshiba vfd + deskcnc controller.
    kind of frankenstain cnc :-)
    Jun 2010
    4256
    There are a LOT of Frankensteins out there, along with their creations ... :rainfro:
    Cheers
    Roger
  1. Replies: 2
    Last Post: 03-02-2017, 01:54 PM
  2. Adding new tool locations - tool changer M6start VB script editor in mach 3
    By demonx in forum Mach Wizards, Macros, & Addons
    Last Post: 12-23-2016, 06:20 AM
  3. Hydraulic belt changer arms on 4020 HT
    By mflux_gamblej in forum Fadal
    Last Post: 11-17-2013, 10:02 AM
