586,071 active members*
3,799 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Usability of Encoder on DC Motor,
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    15362
    Re: Usability of Encoder on DC Motor,
    Quote Originally Posted by Joey2point0 View Post
    With all this being said can someone tell me if the way I plan on setting this up genuinely wont work.
    The encoder is driven by the motor at the same rate as the spindle. (see the photo)
    Should work fine as long as your wiring and Encoder is setup in the software is correct, you will be good to go
    Mactec54
  2. #22
    Mar 2004
    761
    I use AMT102 encoders instead of US Digital.
    https://www.digikey.com/product-deta...1307-ND/827015
    The PPR can be set on the chip. They have been trouble free since installing them over 10 years ago.
    Wayne Hill
  3. #23
    Aug 2009
    230
    I've heard that there is a little bit of delay in those AMT102 encoders... supposedly it works OK for spindle because that just results in a little bit of rotational skew of where the thread ends up; but supposedly it can cause some issues when you try to use it as the shaft encoder on a servo motor???
  4. #24
    Mar 2004
    761
    The AMT102 are used on the shaft of a DC motor. I do not see any delays. It runs five start acme threads reduced down 1:2 at the motor. Anti-backlash nuts. It's fast.
    Wayne Hill
  5. #25
    Aug 2009
    230
    Hmm... well, I've actually got one here - I picked it up for testing - I guess I could rig up a stepper to it as well as a conventional optical encoder that I have here also; and see what it's actual delay is between firing the step pulse and the encoder registering it & outputting it... hmmm...
  6. #26
    Mar 2004
    761
    Sounds like an interesting project. Be sure to secure the cogs on the AMT102. There is a hint of backlash between the plastic cogs that could give false readings.
    Wayne Hill
Page 2 of 2 12
  1. Digitizing and usability
    By Dave Koehler in forum Centroid CNC Control Products
    Last Post: 06-25-2022, 06:58 AM
  2. Alphacam usability
    By rbest42 in forum Alphacam
    Last Post: 12-03-2016, 08:15 AM
  3. HOW TO CHANGE ACTIVE ENCODER FROM LINEAR SCALE TO MOTOR ENCODER IN SIEMENS 840D.
    By sandeepmb123 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-02-2014, 08:05 PM
  4. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
