586,042 active members*
3,807 visitors online*
    Aug 2018
    CNC not cutting from center.
    Aloha,
    Any ideas why my machine is cutting offset from x axis? The shaded line is a straight cut along the x axis from work offset 86.
    These pin locations are to mill the reverse side so I am getting compounded cut error when I turn the part over.
    I am running Fusion360, Mach3 with ESS.
    Thank you.
    Lee
    Attached Files Attached Files
    Aug 2018
    Re: CNC not cutting from center.
    Aug 2018
    Jan 2018
    1516
    Compared to drawing that program makes no sense to me?
    The ruler shows 36.5mm ish spacing yet nothing in that program even adds up to that?
    Seems a mixture of inch and mm measurements in that?
