586,069 active members*
3,484 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Cut quality problem
Results 1 to 20 of 32
Threaded View
    May 2006
    343
    Cut quality problem
    I post this cut quality question on the Mach3 forum. I'm just cutting a simple cam 2.5d profile, it sounds super smooth while cutting but I get slightly wavy and bumpy cuts. This is answer I received, but don't know how to correct this in Rhino or Madcam? Suggestions?
    Check your Gcode - if the curves are comprised of many straight lines then the answer is with your CAD/CAM and it's Post Processor.
    (Vectric, for example, will enable 'curve fit' to replace the many straight lines in an imported dxf and then the final Mach3 post processor will use 'arcs' (G2, G3) for the toolpath).
  1. MAX100 cut quality / nozzle build up problem
    By MrUno in forum Hypertherm Plasma
    Last Post: 08-03-2016, 08:15 AM
  2. Old problem - CO2 laser cut quality in Acrylic sheet
    By Nitrous in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-08-2015, 05:11 PM
  3. Quality Engineer/Quality manager - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:51 PM
  4. Beam quality problem ...
    By smartcut in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-26-2007, 09:17 PM
