586,115 active members*
3,476 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Recovering from powering off KFLOP in middle of Gcode file
Results 1 to 5 of 5
Threaded View
    Apr 2007
    54
    Hello,
    I was running a long session and wanted to pause the machine for day, and did something stupid. This was the last bit of code that ran:
    Code:
    G00
     X30.6715 Y7.0000
    (Pause to load Wire)
    M5
    M100
    M3
    G01 X29.6715
    KmotionCNC is waiting at the last line above, the M100 is set to a wait bit. I had not pressed the button to toggle the bit yet, was going to wait until tomorrow. The machine is at X30.6715 Y7.0000.
    I was shutting down for the night and mistakenly shut off power to Kflop. I reapplied power but the DRO display went yellow and the coordinates were slightly off from the X30.6715 Y7.0000. On the Y it appeared to show without the tool offset. Since I was fubared, I shutoff Kflop. I haven't shut down KmotionCNC. Now the DRO's display the correct values X30.6715 Y7.0000, but yellow.
    What's the correct way to proceed? My init routine zero's the axis. I have a feeling if I leave that in there it will screw things up. Perhaps it's not the place to put it. I've attached my init routine. I assume if I take out the axis zero and run the init everything will work? I can cycle start from the current line?
    Thanks.
    Attached Files Attached Files
  1. Gcode file splitting
    By bigz1 in forum ArtCam Pro
    Last Post: 02-15-2018, 02:08 AM
  2. Cnc stops in the middle of Gcode?
    By Peeps in forum Machines running Mach Software
    Last Post: 02-03-2012, 12:42 PM
  3. Need gcode or dxf file for drilling UHU PCB
    By visky in forum UHU Servo Controllers
    Last Post: 10-07-2008, 08:45 PM
  4. Can Someone Covert File To Gcode?
    By bcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-27-2007, 03:16 AM
  5. How to mirror GCode file?
    By anoah in forum Uncategorised CAM Discussion
    Last Post: 07-08-2003, 06:26 PM
