586,075 active members*
4,240 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazatrol M2 VQC 20/40 most programs will not run
    Jun 2008
    13
    My Mazatrol M2 will run basic milling programs but nothing else. If I have a tap or drill in the program the controller locks up. I have tried changing all of the circuit boards in the cabinet to no avail. I noticed that if the graphics will not run then the machine will not run, so I have been looking carefully at the graphics screen to see what will and will not run and I can get the shape to appear on some drilling and tapping programs but the trace will not appear. The simple point to point milling programs work. There are no error codes.
    I have completely reloaded parameters and tool data etc many times but this has not helped. I have now run out of ideas. Any suggestions?
    Richard
    Sep 2012
    216
    Re: Mazatrol M2 VQC 20/40 most programs will not run
    The trace only shows when the machine is actually running I think. A lot of times even though the shape check works with no errors when you do the tool path it will give you errors. Try the tool path and see what errors you get. It will tell you where they are
    Regards Bob
    Aug 2005
    124
    I have an M2. Give me a little more history. Did it ever run? What exactly do you mean by locks up? In graphics replay? Any message? Running only Mazatrol or can you punch in G-code and it will drill?
  1. Mazatrol M32 sub programs not registered
    By pcreek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-14-2017, 02:28 AM
  2. MAZAK MAZATROL M32 - PARAMETERS AND 844 SUB PROGRAMS
    By taha99 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-23-2015, 04:29 PM
  3. T32-3 Mazatrol running ISO programs
    By jake_tb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-05-2014, 09:30 AM
  4. storing mazatrol programs
    By laamar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-11-2005, 06:43 AM
