586,596 active members*
3,093 visitors online*
Results 1 to 15 of 15
    Nov 2013
    4
    Fanuc 15 TF backup
    Hello to all
    I have a Victor Vturn 20 lathe with a Fanuc 15 TF controller . Beause of the power source malfounction the memory of the controller dont run anymore. Does anybody have a backup of this Fanuc 15 TF .
    This is what i see on the display when i start the machine (image attached).
    Can anybody help me please?
    Thank you in advance.
    Razvan
    Dec 2009
    960
    Re: Fanuc 15 TF backup
    that machine does not exist,was made with 0T system and now has 15TF,there are some VT20 machines with 15TF ,I have a back up from series MA-1968.
    Oct 2007
    9
    I need the parameter and PC parameter for Mori Seiki SL25M Fanuc 15TF.Please help me.
    My email:[email protected]
    Oct 2009
    297
    Quote Originally Posted by hanseols View Post
    Hello:
    What alarms do you have?
    Regards
    Alex Fanuc
    Oct 2007
    9
    Hi after troubleshooting indexing C axis and changing of encoder the Base 0 card was removed and battery power plug to the card accidently pulled out so we have now Ram Parity Base0.
    this machine has for many years had problems with communication on the two ports so no backup has been made.
    All the different "Fanuc" people I hawe been in contact with says you have BIG problems and need special cards etc and all software from Mori Seiki and Fanuc !!!
    The machine was working perfect exept communications with Pc on com port and indexing on C axis; didn't lock on some degrees.
    Hajns
    Apr 2009
    1379
    You lost all parameters (NC+PMC), programs, offsets etc. No boards are needed as far as I can see.
    Oct 2007
    9
    Ok ! I can not get out of IPL screen, Anny Ides ?Attachment 452776
    Apr 2009
    1379
    You will have to turn the control ON holding the 7 & 9 keys pressed until the memory address is counting down. Then you have to clear the FAPT area:
    Power the control ON while pressing the backspace key.
    Then press the “AUX” softkey. It will then ask for a request, type “CFINT”.
    It will ask initialize yes or no, type yes. The screen will message you when it is complete.
    Oct 2009
    297
    Hajns
    As far as I know you do not need any pcb, What is the part number of the BASE 0?
    Alex Fanuc
    Apr 2009
    1379
    Agree with Alex Fanuc, If you see regular screens (mutiple alarms after following my CLEAR procedure), you just have to reload data.
    Oct 2007
    9
    Hi it worked and now I have this on my screen's
    is that meen that PMC and FAPT program is stil there ??Attachment 452868Click image for larger version.
ID:	452870Click image for larger version.
ID:	452872Click image for larger version.
    Apr 2009
    1379
    Now you have to get all the data back in...
    Oct 2007
    9
    Ok parameters and PMC ?? I still locking for a simular machine to ask for a backup ffrom,,!
    Apr 2009
    1379
    Yes, NC and PMC parameters, any 9000 series programs you may need etc,
    Jul 2014
    39
    Hello
    I lost my parameters in Battery fault
    now i need the default parameter.
    I have no backup. thats my fault
    My controller is Fanuc 21it
    My machine is 2 axis lathe (Pinacho Cobra180)
    What can I do now?
    Can u help me pls?
  1. Fanuc oi-td total backup
    By firstName in forum Fanuc
    Last Post: 07-25-2018, 06:59 PM
  2. Fanuc backup
    By Wjman in forum Waterjet General Topics
    Last Post: 02-08-2016, 11:19 AM
  3. Fanuc OM PLC Backup
    By yuem in forum Fanuc
    Last Post: 09-09-2012, 10:20 AM
  4. Fanuc 11M Backup Parameters?
    By giantcake in forum Fanuc
    Last Post: 07-23-2007, 03:34 AM
